Anyone run this water pump setup? #494635
10/11/09 11:42 PM
10/11/09 11:42 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Anyone run this housing with this pump?
I'm wondering what the overall depth would be compared to the 6.8" that my Meziere takes up?
Re: Anyone run this water pump setup? [Re: ProSport] #494636
10/12/09 12:33 AM
10/12/09 12:33 AM
Y-town ohio
68valiant68 Offline
68valiant68  Offline
Y-town ohio
the pump looks like mine, the one in my car is a cvs? maybe they make it for summit. I know the old summit fuel pumps were made by holley. I have had the pump in my car for 4 years. still works good. Eats up a lot of battery though.
Re: Anyone run this water pump setup? [Re: 68valiant68] #494637
10/12/09 07:54 AM
10/12/09 07:54 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Have you measured the overall depth?
Re: Anyone run this water pump setup? [Re: ProSport] #494638
10/12/09 08:31 AM
10/12/09 08:31 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I run that pump,from Summit.The aluminum housing I bought elsewhere years ago,not sure of the brand,but I would assume they are the same depth.
The Summit pump I bought does have CVR on the housing.I just measured mine,5 3/4" from the engine plate to the farthest outward area. I hope that helps.
Re: Anyone run this water pump setup? [Re: Dunnuck Racing] #494639
10/12/09 11:52 AM
10/12/09 11:52 AM
Longview, Texas
marvo451 Offline
marvo451  Offline
Longview, Texas
This JEGS link shows a pump with more GPM and it is shorter, too
http://www.jegs.com/i/JEGS/555/50930/10002/-1#
Re: Anyone run this water pump setup? [Re: marvo451] #494640
10/14/09 11:13 PM
10/14/09 11:13 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
50gpm and takes up less space.
Re: Anyone run this water pump setup? [Re: ProSport] #494641
10/14/09 11:21 PM
10/14/09 11:21 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
I run that set up in my Dart....I also run and aluminum rad and electric fan...the rad is almost in stock location...and it's all...REALLY TIGHT.
