Need a Procharger Guru to Guide Me !! #494577
10/11/09 10:32 PM
10/11/09 10:32 PM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
I currently run a 413 smallblock which I am planning to convert to Procharger horsepower. I need someone to correspond with during this transition so I don't waste money heading the wrong direction. I have a lot of good parts to make a hi-horsepower smallblock.
Anyone willing to correspond and help me get this done??
Re: Need a Procharger Guru to Guide Me !! [Re: Blucuda413] #494578
10/11/09 10:37 PM
10/11/09 10:37 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I believe ProStDodge ran one for awhile. I don't know of too many Mopar guys that have ventured into the ProChargers but I'd sure like to have one.
Re: Need a Procharger Guru to Guide Me !! [Re: ProSport] #494579
10/11/09 10:42 PM
10/11/09 10:42 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
not sure what you are needing to know? don't have any experience with small block mopars but know my way around my setup. If it is at all possible i would highly recommend the supercharger stores geardrive if you plan on making any type of power, alot more friendly on crankshafts. there pretty basic when you break it all down, the hardest part is the initial money and actually getting it all to fit in a given area.
Bigtime just finished up the install in his dart so he may have some good advice too
Re: Need a Procharger Guru to Guide Me !! [Re: prochargedhemi] #494580
10/11/09 10:46 PM
10/11/09 10:46 PM
mo
moparbud Offline
moparbud  Offline
mo
Re: Need a Procharger Guru to Guide Me !! [Re: moparbud] #494581
10/11/09 10:52 PM
10/11/09 10:52 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Bigtime has a Procharger now!??
Pics!
Re: Need a Procharger Guru to Guide Me !! [Re: ProSport] #494582
10/12/09 12:15 AM
10/12/09 12:15 AM
Out West
408strokerdart Offline
Out West
Pics!
I didn't know he was going that route, but if he has it will probably be pretty stout. I would like to hear the details also. I am considering a procharger also so I am interested.
Re: Need a Procharger Guru to Guide Me !! [Re: 408strokerdart] #494583
10/12/09 01:02 AM
10/12/09 01:02 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Ok whatever i can do to help out. Just want to put this out there now, It is not cheap to build a strong combo like this but it is rewarding.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Need a Procharger Guru to Guide Me !! [Re: bigtimeauto] #494584
10/12/09 01:11 AM
10/12/09 01:11 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
What about a setup like this one?
Re: Need a Procharger Guru to Guide Me !! [Re: dodgeboy11] #494585
10/12/09 02:02 AM
10/12/09 02:02 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
I ran a D-1 head unit, made my own brackets, used a cog belt drive. At 188% over-driven I made 13psi in a 500 cid 505hp Mopar crate motor with KB cast pistons - over 730hp with alcohol.
Re: Need a Procharger Guru to Guide Me !! [Re: bigtimeauto] #494586
10/12/09 10:05 AM
10/12/09 10:05 AM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
Looks good!! is that a F2??
Thinking about doing a F2 myself with geardrive unit..
How's it run??
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: Need a Procharger Guru to Guide Me !! [Re: FASTFISH420] #494587
10/12/09 10:10 AM
10/12/09 10:10 AM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
This is the set-up..this is a NMCA motor..F1-R..that Chris Uratchko built.I think it has been 7.90's..in a mustang.
Re: Need a Procharger Guru to Guide Me !! [Re: FASTFISH420] #494588
10/12/09 10:10 AM
10/12/09 10:10 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
How's it run??
Yes on the geardrive. You will need an inner cooler if using gasoline. Fuel injection is the best way to go IMO. Use Motec or BigStuff3 controller. You need to make yourself more clear on your intentions.
Re: Need a Procharger Guru to Guide Me !! [Re: BobR] #494589
10/12/09 10:44 AM
10/12/09 10:44 AM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
I would probably do a blowthru on alky..should make around 1600hp with a F2..
Re: Need a Procharger Guru to Guide Me !! [Re: FASTFISH420] #494590
10/12/09 12:33 PM
10/12/09 12:33 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I am in the build process.
I went Fuel injection right away to help meter the fuel for a street strip combo
I was on the passenger side but but switching to drivers side for a bit more room
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Need a Procharger Guru to Guide Me !! [Re: Kam*Kuda] #494591
10/12/09 12:34 PM
10/12/09 12:34 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Will be incorporating into the motor-plate
1654.5 Mustang
1955 Land Rover
Re: Need a Procharger Guru to Guide Me !! [Re: Kam*Kuda] #494592
10/12/09 12:40 PM
10/12/09 12:40 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Some note and Thoughts Note I am a novice and I am learning from my one mistakes and those of others
I have been working with The Stig Jr (moparts member) He has more experience and his stock looking Road Runner is fast
Fuel
From what I have seen, fuel metering is critical. It is difficult to meter a street strip blow thru application with a carb that is designed to operate on vacuum... but it certainly able to be done an many have done it successfully.
I went to EFI to meter it better and easily build a conservative fuel and timing curve and them.
Have enough fuel system to supply. It appear easy to build boost, you just need the fuel system to support to feed it.
1654.5 Mustang
1955 Land Rover
Re: Need a Procharger Guru to Guide Me !! [Re: Kam*Kuda] #494593
10/12/09 12:42 PM
10/12/09 12:42 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Have a good to ignition system. You will need decent spark.
Heat is your enemy. Piston coating seem to work well and protect the engine a bit.
Water/Meth injection and or an intercooler will help cool the air that gets HEATED by the procharger.
1654.5 Mustang
1955 Land Rover
Re: Need a Procharger Guru to Guide Me !! [Re: Kam*Kuda] #494594
10/12/09 12:45 PM
10/12/09 12:45 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I hear differing stories on compression. Many state the standard rule of lowering compression and running your boost. Some have bolted a procharger on a 10.5 compression engine and ran VERY well. There is a local guy who did this with a small block demon (10-1 I think). The power impressed/scared him. No long term report good or bad on this plan as far as engine longevity.
1654.5 Mustang
1955 Land Rover
Re: Need a Procharger Guru to Guide Me !! [Re: Kam*Kuda] #494595
10/12/09 01:29 PM
10/12/09 01:29 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
You could try Steve Morris @ http://www.neweraracecraft.com/
HTH's
Re: Need a Procharger Guru to Guide Me !! [Re: Tig] #494596
10/12/09 01:37 PM
10/12/09 01:37 PM
Hemiroid Offline
Hemiroid  Offline
Steve Morris is the man! And a nice guy as well
