Page 1 of 3 1 2 3
5.7 vs 6.1 new hemi #494169
10/11/09 04:20 PM
10/11/09 04:20 PM
Indian Hills, CO
mdurbahn Offline OP
super street
mdurbahn  Offline OP
super street
Indian Hills, CO
I will be doing a new hemi swap into a b-body, I am trying to compare the 5.7 to 6.1 to see what would be best for me. I like the 6.1 because it has more hp, but it is quite a bit more expensive for not much more hp, would it be better to build the 5.7 up a little or go for the 6.1
67 Coronet R/T 911 Turbo
Re: 5.7 vs 6.1 new hemi [Re: mdurbahn] #494170
10/11/09 04:46 PM
10/11/09 04:46 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
I read in an article where simple mods can bring you up to the 400 hp mark fairly easily in the 5.7 (headers, cam, different chip) personally, I think anyone can be relativly happy with the 5.7 as they are pretty quick and way cheaper than the 6.1 not to mention easier to find. it just my though.
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: 5.7 vs 6.1 new hemi [Re: mopars_1] #494171
10/11/09 05:13 PM
10/11/09 05:13 PM
Indian Hills, CO
mdurbahn Offline OP
super street
mdurbahn  Offline OP
super street
Indian Hills, CO
that is kinda what i figured, i haven't been able to find a 6.1 either.
Re: 5.7 vs 6.1 new hemi [Re: mdurbahn] #494172
10/11/09 08:24 PM
10/11/09 08:24 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
It depends on how fast you want to go, a 5.7 should run mid to high 12's in a B body stock as-is, general rule of thumb on HP is 400hp with headers, 500hp with headers/street cam and a little head work and 700+ with a paxton/vortech.
I've ran 13.40's with one in a 4200# car mostly stock with 2.82 gears.
Re: 5.7 vs 6.1 new hemi [Re: MoparJoe] #494173
10/11/09 09:12 PM
10/11/09 09:12 PM
wisconsin
swifter Offline
swifter  Offline
wisconsin
Go with the 5.7-Easier to find--Take care of the heads--Problems with higher lift (aftermarket cams)
lift,,Put the 6.1 valves in and will flow as much as the 6.1!!!!I used xv's kit putting out 428hp now,I also went the uncommon route and used the car timing cover set-up to hide the alternator--Steve
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
Re: 5.7 vs 6.1 new hemi [Re: MoparJoe] #494174
10/11/09 10:11 PM
10/11/09 10:11 PM
Indian Hills, CO
mdurbahn Offline OP
super street
mdurbahn  Offline OP
super street
Indian Hills, CO
Hmm I bet I could get a 5.7 with a vortech for the same price as a 6.1
Re: 5.7 vs 6.1 new hemi [Re: swifter] #494175
10/11/09 10:14 PM
10/11/09 10:14 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
A 5.7 with the new stroker kit IS a 6.4 hemi....And then CNC port the heads, and 600hp is very possible.
Re: 5.7 vs 6.1 new hemi [Re: mdurbahn] #494176
10/11/09 10:19 PM
10/11/09 10:19 PM
IN
ahy Offline
ahy  Offline
IN
The 6.1 has forged pistons and rods. To handle the higher power of a high boost supercharger or a max effort NA build, they would need to be added to the 5.7 to keep it alive. As posted, it depends on what your goals are.
Re: 5.7 vs 6.1 new hemi [Re: ahy] #494177
10/11/09 11:23 PM
10/11/09 11:23 PM
Castle Rock, CO
W
wegner426 Offline
wegner426  Offline
W
Castle Rock, CO
Wrong Wrong Wrong....The only forged piece in the 6.1 is the crank. Rods are powdered metal, pistons are cast.
Re: 5.7 vs 6.1 new hemi [Re: wegner426] #494178
10/12/09 12:11 AM
10/12/09 12:11 AM
Indian Hills, CO
mdurbahn Offline OP
super street
mdurbahn  Offline OP
super street
Indian Hills, CO
wegner- did you do a 3rd gen swap into that cuda? i see you are in castle rock, i work in tech center and would like to check it out if you did.
Re: 5.7 vs 6.1 new hemi [Re: mdurbahn] #494179
10/12/09 12:22 AM
10/12/09 12:22 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Either way they make a ton of power. Added plus for the 6.1L is the forged crank and the piston oil sprayer system which really helps the durability.
Leave the gun.......take the Cannoli's....Mike
Re: 5.7 vs 6.1 new hemi [Re: mdurbahn] #494180
10/12/09 10:20 AM
10/12/09 10:20 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Just took my 06 5.7 Magnum R/T AWD car to the track. Ran 14.56. I think with a good program it will run high 13's. Not bad for a 4200lb car. I'd think either would work for you depneding. I'd guess the 5.7 would be cheaper???
Coming soon!!!!
Re: 5.7 vs 6.1 new hemi [Re: Mr.Yuck] #494181
10/12/09 06:03 PM
10/12/09 06:03 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
working on 6.1 in 71 runner, having a few idle issues, but seems good so far! A little exhaust port work, good 5 angle valve job, and mid size comp cam.
Re: 5.7 vs 6.1 new hemi [Re: Mr.Yuck] #494182
10/12/09 06:17 PM
10/12/09 06:17 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Want an EASY "mod"?
Toss a jump over the fan relay and get the fans on all the time. Hard to believe, but it works better than I thought, that's for sure...
CrAzYMoPaRGuY
Re: 5.7 vs 6.1 new hemi [Re: hemibeep] #494183
10/12/09 07:32 PM
10/12/09 07:32 PM
Canada
DmanSRT71 Offline
DmanSRT71  Offline
Canada
What engine management are you using?
I'm torn between making the stock computer work, or buying the stand alone.
69 Road Runner 383/auto/N96 71 Demon 340/4 spd Would like to find a rust free Cuda body.
Re: 5.7 vs 6.1 new hemi [Re: wegner426] #494184
10/13/09 08:32 AM
10/13/09 08:32 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
isn't there a sodium filled exhaust valve to think about too?
based on the past
I am wondering if a few years from now
there will be a rash of exhaust valve failures
in high mileage 6.1 V8s
Re: 5.7 vs 6.1 new hemi [Re: CrAzYMoPaRGuY] #494185
10/13/09 09:09 AM
10/13/09 09:09 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Want an EASY "mod"?
really? why because it keeps the block nice and cool? I also notice that it seems the air doesn't get to the box so nice. Wonder how much some fresh air would help??
Coming soon!!!!
Re: 5.7 vs 6.1 new hemi [Re: DmanSRT71] #494186
10/13/09 09:15 AM
10/13/09 09:15 AM
Almont, MI.
gdemon Offline
gdemon  Offline
Almont, MI.
Im using a 2004 ram computer with a custom flash and a harness form HOTWIRE.com
Jerry
69 Barracuda 70 Cuda 70 Cuda 70 Cuda Conv. 70 T/A Challenger 70 Sport Fury GT 71 Demon 5.7 Hemi 72 Demon
Re: 5.7 vs 6.1 new hemi [Re: gdemon] #494187
10/13/09 06:19 PM
10/13/09 06:19 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
i am also using 04' ram manual tranny computer and hotwire wiring.
Has anyone else had idle issues with this setup???
O
Re: 5.7 vs 6.1 new hemi [Re: gdemon] #494188
10/13/09 09:20 PM
10/13/09 09:20 PM
Canada
DmanSRT71 Offline
DmanSRT71  Offline
Canada
Thanks Jerry.
So you needed the custom flash because the 04 Ram was running a 5.7, and the 6.1 obviously needed a different program......but it WASN'T a flash to disable any of the unnecessary items that your car wouldn't use vs. the truck? (ie like air bags, auto trans inputs/outputs, ABS....etc) Is that an appropriate comment?
And how did you (or the hotwire auto harness) get around the built in security in that engine controller?
Edit (addition): Where does one purchase an 04 ram manual trans engine controller?
Darren
Page 1 of 3 1 2 3
