5.7 vs 6.1 new hemi
#494169
10/11/09 04:20 PM
10/11/09 04:20 PM
Posts: 148 Indian Hills, CO
mdurbahn
super street
super street
Indian Hills, CO
I will be doing a new hemi swap into a b-body, I am trying to compare the 5.7 to 6.1 to see what would be best for me. I like the 6.1 because it has more hp, but it is quite a bit more expensive for not much more hp, would it be better to build the 5.7 up a little or go for the 6.1
67 Coronet R/T
911 Turbo
Re: 5.7 vs 6.1 new hemi
[Re: mdurbahn]
#494170
10/11/09 04:46 PM
10/11/09 04:46 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
I read in an article where simple mods can bring you up to the 400 hp mark fairly easily in the 5.7 (headers, cam, different chip) personally, I think anyone can be relativly happy with the 5.7 as they are pretty quick and way cheaper than the 6.1 not to mention easier to find. it just my though.
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: MoparJoe]
#494173
10/11/09 09:12 PM
10/11/09 09:12 PM
Posts: 301 wisconsin
swifter
wisconsin
Go with the 5.7-Easier to find--Take care of the heads--Problems with higher lift (aftermarket cams) lift,,Put the 6.1 valves in and will flow as much as the 6.1!!!!I used xv's kit putting out 428hp now,I also went the uncommon route and used the car timing cover set-up to hide the alternator--Steve
2007 Ram 2500 Cummins
2008 Dodge Nitro
1970 340 Valiant Duster
[Re: ahy]
#494177
10/11/09 11:23 PM
10/11/09 11:23 PM
Posts: 310 Castle Rock, CO
wegner426
Castle Rock, CO
The 6.1 has forged pistons and rods. To handle the higher power of a high boost supercharger or a max effort NA build, they would need to be added to the 5.7 to keep it alive. As posted, it depends on what your goals are.
Wrong Wrong Wrong....The only forged piece in the 6.1 is the crank. Rods are powdered metal, pistons are cast.
[Re: wegner426]
#494178
10/12/09 12:11 AM
10/12/09 12:11 AM
mdurbahn
super street
super street
Indian Hills, CO
wegner- did you do a 3rd gen swap into that cuda? i see you are in castle rock, i work in tech center and would like to check it out if you did. Quote:
67 Coronet R/T
911 Turbo
[Re: mdurbahn]
#494179
10/12/09 12:22 AM
10/12/09 12:22 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Either way they make a ton of power. Added plus for the 6.1L is the forged crank and the piston oil sprayer system which really helps the durability.
Leave the gun.......take the Cannoli's....Mike
[Re: hemibeep]
#494183
10/12/09 07:32 PM
10/12/09 07:32 PM
Posts: 375 Canada
DmanSRT71
Canada
What engine management are you using? I'm torn between making the stock computer work, or buying the stand alone. Quote:
working on 6.1 in 71 runner, having a few idle issues, but seems good so far! A little exhaust port work, good 5 angle valve job, and mid size comp cam.
69 Road Runner 383/auto/N96
71 Demon 340/4 spd
Would like to find a rust free Cuda body.
[Re: CrAzYMoPaRGuY]
#494185
10/13/09 09:09 AM
10/13/09 09:09 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Just took my 06 5.7 Magnum R/T AWD car to the track. Ran 14.56. I think with a good program it will run high 13's. Not bad for a 4200lb car. I'd think either would work for you depneding. I'd guess the 5.7 would be cheaper???
Want an EASY "mod"? Toss a jump over the fan relay and get the fans on all the time. Hard to believe, but it works better than I thought, that's for sure...
really? why because it keeps the block nice and cool? I also notice that it seems the air doesn't get to the box so nice. Wonder how much some fresh air would help??
[Re: DmanSRT71]
#494186
10/13/09 09:15 AM
10/13/09 09:15 AM
Posts: 387 Almont, MI.
gdemon
Almont, MI.
Im using a 2004 ram computer with a custom flash and a harness form HOTWIRE.com
Jerry
69 Barracuda
70 Cuda
70 Cuda
70 Cuda Conv.
70 T/A Challenger
70 Sport Fury GT
71 Demon 5.7 Hemi
72 Demon
[Re: gdemon]
#494188
10/13/09 09:20 PM
10/13/09 09:20 PM
Posts: 375 Canada
DmanSRT71
Canada
Thanks Jerry. So you needed the custom flash because the 04 Ram was running a 5.7, and the 6.1 obviously needed a different program......but it WASN'T a flash to disable any of the unnecessary items that your car wouldn't use vs. the truck? (ie like air bags, auto trans inputs/outputs, ABS....etc) Is that an appropriate comment?
And how did you (or the hotwire auto harness) get around the built in security in that engine controller?
Edit (addition): Where does one purchase an 04 ram manual trans engine controller?
Thanks Darren
71 Demon 340/4 spd
