Relocated battery wiring diagram #492942
10/10/09 11:42 AM
10/10/09 11:42 AM
Pikes Peak Country
TC@HP2 Offline OP
TC@HP2  Offline OP
Pikes Peak Country
Some time ago I read a thread on here about how to wire up a trunk mounted battery so the main cable to the starter was only live during cranking. I think it used a ford solenoid. Does anyone have a diagram on such a set up? How does that set up work with the alternator putting juice back in to the system? Does the alternator require a separate lead to keep juice out of the battery cable?
Re: Relocated battery wiring diagram [Re: TC@HP2] #492943
10/10/09 12:30 PM
10/10/09 12:30 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you should be able to find something here.
http://www.painlessperformance.com/manuals.php
Re: Relocated battery wiring diagram [Re: TC@HP2] #492944
10/10/09 08:51 PM
10/10/09 08:51 PM
Raleigh, NC
Y
Youngblood Offline
Youngblood  Offline
Y
Raleigh, NC
You use a Ford solenoid out back, close to battery with fusible link protection. Have to run heavy charge wire to battery as well. I think you are referring to the diagrams from Mark at MAD ELECTRICAL. Try madelectrical.com
Re: Relocated battery wiring diagram [Re: Youngblood] #492945
10/10/09 10:14 PM
10/10/09 10:14 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I have a diagram so the alternator wire is only hot when the switch is on. Not sure why you want to kill the main wire to the starter.
Re: Relocated battery wiring diagram [Re: Bigcube] #492946
10/10/09 11:06 PM
10/10/09 11:06 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Starter line normally cold and alt cold when switch is tossed
