Some time ago I read a thread on here about how to wire up a trunk mounted battery so the main cable to the starter was only live during cranking. I think it used a ford solenoid. Does anyone have a diagram on such a set up? How does that set up work with the alternator putting juice back in to the system? Does the alternator require a separate lead to keep juice out of the battery cable?
