Wiper arm removal ? #492447
10/09/09 01:31 PM
10/09/09 01:31 PM
Albany, NY
67SATisfaction Offline OP
The member whose name is actually Art
Albany, NY
(65 Plymouth Satellite)
What's the method for removing wiper arms from the pivot stem at base of windshield?
Special tool?
Thanks!
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Wiper arm removal ? [Re: 67SATisfaction] #492448
10/09/09 02:14 PM
10/09/09 02:14 PM
Albany, NY
Albany, NY
I got it.... the FSM shows a prying tool that holds the sprung load, so I'm not sure how I'll put them back, but to remove them...
.. Lubed it with PB Blaster, wedged a thin wood shim against the body panel to protect it, used a sturdy gasket scraper to pry up between the shim and the edge of the wiper knuckle while I used a bamboo scewer to push the lock tab in the open position.
- Art
Re: Wiper arm removal ? [Re: 67SATisfaction] #492449
10/09/09 02:26 PM
10/09/09 02:26 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I usually just put flat aluminum covers over the jaws of my vice grip so the teeth do not score the arms themselves, clamp it on and then wiggle it back and forth. When you get them off just put the arm down on a cloth on your bench, whack the rivet inside with a drift pin and hammer that holds the spring inside the splined area to restore its place and loaded action and press the spring back to its normal tightened position. Put on a tiny amount of anti-seize for the next time, if you put too much it could come apart in the rain....DAMHIK
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
