Re: Electrical- Lights flickering bright/normal volts 14-15
[Re: 69CopperCoronet]
#492118
10/08/09 11:21 PM
10/08/09 11:21 PM
Posts: 1,609 Southern Cal
Noblewk
Southern Cal
change out your voltage regulator.
66 Dart GT, 402 11.18:109 Best
63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best
2000 Ram
2005 Durango Hemi.
[Re: Noblewk]
#492119
10/09/09 09:14 PM
10/09/09 09:14 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You ahve a mechanical voltage regulator.
They are adjustible, but they make an electronic version that does a better job. I'd get one of them.
[Re: Lefty]
#492121
10/10/09 11:52 AM
10/10/09 11:52 AM
Posts: 3,344 Central TX
roe
Central TX
My car was doing something similar. The lights would flicker noticably while driving, would dim really bad at stoplights. It finally blew out a fusible link. Found out there was an internal short/ground inside the alternator when I got it tested. Replaced the fusible link and alternator and all symptoms are cured. roe ![](/ubbthreads/images/graemlins/Twocents.gif)
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
