Re: First drive with the E85
[Re: Cheatham]
#491180
10/07/09 11:41 PM
10/07/09 11:41 PM
Posts: 705 Michigan
Hemiroid
Finally after a couple of months of cutting and welding for the ladder bars and getting the AED dominator converted to E85 and getting the license plates updated i took the car out and is much more responsive and runs much cooler, at 96F and the /6 radiator and 180 thermostat the car cruises at 185 deg, it used approx. 7gallon on a 11 mile drive and motor has much more blubber due to the richer carb setting for e85, i didnt open it up all the way but you know by the feel of the pants that it got alot of grunt in it waiting to be unleashed, the sound of the motor with the new carb conversion is much stouter as should be expected, anyone thinking about doing the e85 should do it, the exh.fumes smell ok too after getting use to it,kinda like burnt popcorn oil.
Wha wha WHAT?!?! Seven gallons to go 11 miles???
[Re: joshking440]
#491183
10/08/09 11:54 AM
10/08/09 11:54 AM
Posts: 456 corpus christi tex
Cheatham
corpus christi tex
There is no way that you used 7 gallons to go eleven miles. 1.57 miles to the gallon??? That has to be about 4000 horsepower...
My mistake i was thinking one way on the drive. it was a 21-22 mile drive.
[Re: joshking440]
#491186
10/08/09 02:00 PM
10/08/09 02:00 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
thats always been my criticzm.. no soccer mom is gonna stand there and pump 80gal into her suburban... the mile per gallon montra has been thoroughly indoctinated into society.. cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#491187
10/08/09 09:08 PM
10/08/09 09:08 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Well my junk gets 7-8 mpg on E85 with 4.30 gears. Got about 10 on gas with 3.23s.
The LM-2 helped me lot with cruise afr with the E85.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#491188
10/08/09 09:48 PM
10/08/09 09:48 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
FYI Little off topic My dragster on Alky (methanol) not Ethanol drunk the fuel. From pit to staging lane with the barrel valve near shut, on to the burn out box, through the 8th mile pass, back to pits would burn 2 gallons of fuel. The only time the barrel valve was fully opened was during the burn out, and 8th mile pass. From and too the that point it was at a idle and barrel valve was damn near shut. You would need a tanker truck following you around to drive that thing on the street, if it were in a door slammer LOL. So how does 6-8 gallons per mile strike ya?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Cheatham]
#491189
10/09/09 10:49 AM
10/09/09 10:49 AM
Posts: 16,928 NC
440Jim
NC
I like the E85 too! The smell is good, not offensive, I think of it as some kind of cooking smell. On methanol, my car used 1.5 gallons per run (I was stingy), with E85 it is 1.0, and with gas it was 0.7 I have seen some methanol setups burn tons of fuel, one guys says he uses 3 gallons per run!
