First drive with the E85 #491178
10/07/09 11:17 PM
10/07/09 11:17 PM
corpus christi tex
Cheatham Offline OP
Cheatham  Offline OP
corpus christi tex
Finally after a couple of months of cutting and welding for the ladder bars and getting the AED dominator converted to E85 and getting the license plates updated i took the car out and is much more responsive and runs much cooler, at 96F and the /6 radiator and 180 thermostat the car cruises at 185 deg, it used approx. 7gallon on a 11 mile drive and motor has much more blubber due to the richer carb setting for e85, i didnt open it up all the way but you know by the feel of the pants that it got alot of grunt in it waiting to be unleashed, the sound of the motor with the new carb conversion is much stouter as should be expected, anyone thinking about doing the e85 should do it, the exh.fumes smell ok too after getting use to it,kinda like burnt popcorn oil.
Re: First drive with the E85 [Re: Cheatham] #491179
10/07/09 11:24 PM
10/07/09 11:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Get it leaned out and it'll be much quicker, should
be about 30% more than gas
Re: First drive with the E85 [Re: Cheatham] #491180
10/07/09 11:41 PM
10/07/09 11:41 PM
Hemiroid Offline
Hemiroid  Offline
Wha wha WHAT?!?! Seven gallons to go 11 miles???
Re: First drive with the E85 [Re: Hemiroid] #491181
10/08/09 09:39 AM
10/08/09 09:39 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
There is no way that you used 7 gallons to go eleven miles. 1.57 miles to the gallon??? That has to be about 4000 horsepower...
Re: First drive with the E85 [Re: joshking440] #491182
10/08/09 09:49 AM
10/08/09 09:49 AM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
I think he meant "approx .7 gallon".
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: First drive with the E85 [Re: joshking440] #491183
10/08/09 11:54 AM
10/08/09 11:54 AM
corpus christi tex
Cheatham Offline OP
Cheatham  Offline OP
corpus christi tex
My mistake i was thinking one way on the drive. it was a 21-22 mile drive.
Re: First drive with the E85 [Re: Cheatham] #491184
10/08/09 12:37 PM
10/08/09 12:37 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
well we are up to 3.14 miles per gallon, i think we have solved our dependency on foreign oil with this one...
Re: First drive with the E85 [Re: joshking440] #491185
10/08/09 02:00 PM
10/08/09 02:00 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
might want to lean it up a bit...
Re: First drive with the E85 [Re: joshking440] #491186
10/08/09 02:00 PM
10/08/09 02:00 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
thats always been my criticzm..
no soccer mom is gonna stand there and pump 80gal into her suburban...
the mile per gallon montra has been thoroughly indoctinated into society..
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: First drive with the E85 [Re: cheapstreetdustr] #491187
10/08/09 09:08 PM
10/08/09 09:08 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Well my junk gets 7-8 mpg on E85 with 4.30 gears. Got about 10 on gas with 3.23s.
The LM-2 helped me lot with cruise afr with the E85.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: First drive with the E85 [Re: Von] #491188
10/08/09 09:48 PM
10/08/09 09:48 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
FYI
Little off topic
My dragster on Alky (methanol) not Ethanol drunk the fuel. From pit to staging lane with the barrel valve near shut, on to the burn out box, through the 8th mile pass, back to pits would burn 2 gallons of fuel. The only time the barrel valve was fully opened was during the burn out, and 8th mile pass. From and too the that point it was at a idle and barrel valve was damn near shut.
You would need a tanker truck following you around to drive that thing on the street, if it were in a door slammer LOL.
So how does 6-8 gallons per mile strike ya?
Re: First drive with the E85 [Re: Cheatham] #491189
10/09/09 10:49 AM
10/09/09 10:49 AM
NC
440Jim Offline
440Jim  Offline
NC
I like the E85 too!
The smell is good, not offensive, I think of it as some kind of cooking smell.
On methanol, my car used 1.5 gallons per run (I was stingy), with E85 it is 1.0, and with gas it was 0.7
I have seen some methanol setups burn tons of fuel, one guys says he uses 3 gallons per run!
