Carb selection - upgrade stock 318 to 4 barrel-Options? #490933
10/07/09 07:19 PM
10/07/09 07:19 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
Hey guys, if you saw my other post I'm upgrading
my stock 318 to a 4 barrel MP aluminum intake.
What carbs do you guys put on this?
Holley 600 cfm or an Edelbrock AVS 500?
or..what do you guys use..
Its a stock 318 with single exhaust.
I will be upgrading to dual exhaust later on
but for now I just want to upgrade to a
small 4 barrel..
What do you guys use/recommend... thanks!
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: OLD318] #490934
10/07/09 07:47 PM
10/07/09 07:47 PM
my stock 318 What carbs do you guys put on this? What do you guys recommend... thanks!
Edelbrock.
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: RapidRobert] #490935
10/07/09 07:55 PM
10/07/09 07:55 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
edelbrock. I'd go 600 and jet it down if you need to. The Eddys aren't a rich carb. 600 should be fine right out of the box.
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: Dougsmopars] #490936
10/07/09 09:13 PM
10/07/09 09:13 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Where's the double pumper crowd???
Edelbrock 600
Don't be the exception.
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: Supercuda] #490937
10/07/09 09:51 PM
10/07/09 09:51 PM
Dougsmopars Offline
Dougsmopars  Offline
Don't get them started
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: Dougsmopars] #490938
10/07/09 09:59 PM
10/07/09 09:59 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've got a spreadbore holley 650 double pumper he could buy...
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: DaytonaTurbo] #490939
10/07/09 10:44 PM
10/07/09 10:44 PM
Dougsmopars Offline
Dougsmopars  Offline
I;'ve got a 780 DP i use for a door stop
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: Dougsmopars] #490940
10/08/09 08:06 AM
10/08/09 08:06 AM
scratchnfotraction Offline
600 eddy would be good for a stockish 318
I also like a early to mid 70s chivy q-jet with the mopar throttle lever tac welded on to the throttle shaft for stock mopar 4-v linkage
that works great on a 318 also,IMO
any smaller holley would do..
remember 318 are easy to "over cam" which means they are easy to "over carb" also
I have ran a 750cfm on a stock teen..had good top end..but the idle was pig rich and slow speed drivabilty was sluggish till 3000 rpms or so
600 eddy out the box was almost right on the jetting but still a tad rich,IMO
good luck and dont over carb it with a stock cam
dont forget to get the throttle presssure rod adjusted correctly or you will be posting about new trannys for it
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: scratchnfotraction] #490941
10/08/09 06:28 PM
10/08/09 06:28 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
What about the Thunder AVS 500 cfm
Is that a better choice than a 600 CFM for
a 318.... anyone use the 500?
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: OLD318] #490942
10/08/09 06:49 PM
10/08/09 06:49 PM
Holley 600...
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? #490943
10/08/09 06:57 PM
10/08/09 06:57 PM
Staten Island, NY
Theorio1025 Offline
Theorio1025  Offline
Staten Island, NY
I had a holley 600 cfm vac. secondary on my camaro and I liked it. The car was run as a daily driver, even through the winter. Tried an Edelbrock 600 on the same car, and I don't think it ran as well.
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: Theorio1025] #490944
10/09/09 07:57 AM
10/09/09 07:57 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
eddie 600 is a good choice as it gives some room to grow. I have a 1406 on my magnum headed 318 with a 208@.050, .506" lift roller cam, RPM air gap and headers. I had to change the step up springs to the pink or natural, jet the primary down to .095" jets and .073/.052 rods and the secondary down to .089 jets. that was tuning with an LM1.
2017 Grand Cherokee Overland
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: patrick] #490945
10/09/09 01:16 PM
10/09/09 01:16 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
The one I was looking at is the Holley 80457S
model which is a universal 600 CFM 4 barrel
with electric choke and vacuum secondaries.
Brand new it runs around $275.00
which seems reasonable...
(The Thunder AVS 500 is around $350.00 )
Anybody use this one (holley)?
I have to use a 1" spacer to get this to fit.
on the MP Aluminum intake...
I've got the spacer and mopar "pieces" to connect
to the existing throttle linkage...
I understand I'll have to adjust the throttle
linkage to get this to work properly.
One more question I've got a 340 single 4 barrel
air cleaner... will this fit on the holley,
it looks like it will.... But I've never tried it
Anybody know?
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: OLD318] #490946
10/09/09 03:37 PM
10/09/09 03:37 PM
yes it will fit the holley gas hole
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: scratchnfotraction] #490947
10/09/09 04:54 PM
10/09/09 04:54 PM
Hampden, Maine
Procommuter Offline
super street
Procommuter  Offline
super street
Hampden, Maine
Don't forget to use four barrell intake gaskets not the steel shim two barrell gaskets. AMHIK. One of the first things I learned on my first mopar.
Wes 73 Barracuda 440 EFI 4 speed, 144.85 MPH LTA A/FSS Record Holder.
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: Procommuter] #490948
10/10/09 04:35 PM
10/10/09 04:35 PM
Central NC
gch Offline
gch  Offline
Central NC
The carb choice is your preference.I would run 600 cfm what ever you choose.It won't hurt you now and will support upgrades later.
Honestly I think dual exhaust will help more than a 4 barrell.Be prepeared to re-tune it after you swap exhaust.
At a minimum I would install a high flow muffler even with single exhaust.Stock (quiet) mufflers are very restrictive.
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: gch] #490949
10/10/09 09:22 PM
10/10/09 09:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Quiet doesn't mean restrictive, nor does loud mean best flowing.
Car Craft, and others, have done a number of tests and the Dynomay Hemi muffler is the winner. Quiet, free flowing, cheap. On the dyno, with a sound meter, real tests not someone's guess.
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: Supercuda] #490950
10/15/09 11:31 AM
10/15/09 11:31 AM
O
OLD318 Offline OP
OLD318  Offline OP
O
When you guys switch from 2bbl to 4bbl
do you retain the 5/16 stock fuel line
or do you also convert the fuel pump/ steel lines
to 3/8..
Is this part of the conversion for a stock
318 from 2bbl to 4bbl?
What do you guys do?
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: OLD318] #490951
10/15/09 12:51 PM
10/15/09 12:51 PM
if you plan on keeping it under 300hp then the 5/16 fuel lines will be fine.
Re: Carb selection - upgrade stock 318 to 4 barrel-Options? [Re: Supercuda] #490952
10/15/09 01:16 PM
10/15/09 01:16 PM
Central NC
gch Offline
gch  Offline
Central NC
I agree with you but most stock mufflers I have seen are both quiet and restrictive compared to an aftermarket turbo style muffler(dynomax).
The 5/16 fuel line is sufficient.
