Another 440 Cam Selection Thread #490743
10/07/09 04:22 PM
10/07/09 04:22 PM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
Need some help figuring what cam to put in.
1 9.3 comp ratio
2 factory intake and exhaust manifolds and heads.
3 650 Holley vacuum secondary
4 currently 3.55 rear probably will put in 2.96
5 727 auto
6 71 Road Runner
7 Want to have enough vacuum for power brakes to still work
8 want to set for street car I can drive long distances, not racing it.
Want more than a stock cam, with some decent pull to it.
Any help will be appreciated.
Re: Another 440 Cam Selection Thread [Re: CYACOP] #490744
10/07/09 05:49 PM
10/07/09 05:49 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Something around 220@.050 and .500 lift would get you there.
Re: Another 440 Cam Selection Thread [Re: bobby66] #490745
10/07/09 08:20 PM
10/07/09 08:20 PM
IA
landon1 Offline
landon1  Offline
IA
i have almost same combo in my car - i chose the XE268 - i don't have power brakes, but i'm sure it makes enough vacuum - this cam that's supposed to be a bit "lopey" really isn't at all - kinda sounds like an old train at idle
'71 Satellite Sebring 440
Re: Another 440 Cam Selection Thread [Re: landon1] #490746
10/07/09 08:45 PM
10/07/09 08:45 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I run the lunati voodoo 60303 and my power brakes work as well as they did with the stock cam. For your mild combo and gearing I would try the voodoo 60302. The 302's 220/226 @050 duration, .479/.494 lift and ground on a 112 lsa. Should be a good cam for your application.
FWIW even the 'big' summit cam would do well in your application.
Re: Another 440 Cam Selection Thread [Re: CYACOP] #490747
10/07/09 10:27 PM
10/07/09 10:27 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I have a .030 over 440, 9.35 to 1 measured compression, mild iron heads, block hugger type headers, and an Edelbrock CH28. My car is 3500 pounds and it has 3.08 gears. I went with a Comp Cams 270H grind.
CrAzYMoPaRGuY
Re: Another 440 Cam Selection Thread [Re: CYACOP] #490748
10/08/09 07:04 AM
10/08/09 07:04 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Smaller Summit cam. Cheap and will work w/ your almost stock build.
Coming soon!!!!
Re: Another 440 Cam Selection Thread [Re: DaytonaTurbo] #490749
10/08/09 08:25 AM
10/08/09 08:25 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
that's the cam I'd use (60302)
2017 Grand Cherokee Overland
Re: Another 440 Cam Selection Thread [Re: patrick] #490750
10/08/09 09:35 AM
10/08/09 09:35 AM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
Thanks for the suggestions, those were the cams I have been looking at. I will probably go with the 60302
Re: Another 440 Cam Selection Thread [Re: Mr.Yuck] #490751
10/08/09 09:13 PM
10/08/09 09:13 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
This is what I'm running my mine.
Moparlee
