'69 Dart 440 Header Question #490409
10/07/09 08:20 AM
10/07/09 08:20 AM
Wisconsin USA
Albert Lee Offline OP
Wisconsin USA
Is TTI the only/best header for this applcation?
Details: Drag Race Only, 440, Indy EZ 295 Heads, 727 Automatic, Manual Steering and Brakes, Front Motor Plate.
I think I'm looking for 2" headers with an easy fit. Pictures are a big plus.
Thanks in advance for your experience and suggestions!
AlbertLee4@gmail.com
Re: '69 Dart 440 Header Question [Re: Albert Lee] #490410
10/07/09 09:18 AM
10/07/09 09:18 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
If you're looking for an easy fit i'd forget TTI's, my 69 440 has got them, starter access is almost nil, also, i have to take the torsion bars out, lift and tilt the motor to get them in or out.
Hookers or pro parts are easier to take out but you will have to cut the inner fenders and front tyre clearance is tight with the hookers.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: '69 Dart 440 Header Question [Re: Albert Lee] #490411
10/07/09 12:45 PM
10/07/09 12:45 PM
I like the fenderwell headers way better than the chassis headers in a A body with a BB motor. I have used a set of Pro Parts, Hookers and Hedman heads on my Duster and I now a set of Mad Dogs chassis headers for the Dart. For racing the fenderwells are way better to work on the car
Re: '69 Dart 440 Header Question [Re: Cab_Burge] #490412
10/07/09 01:03 PM
10/07/09 01:03 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Fenderwells all the way for me.I cant even imagine the headache of TTi.
Tire clearance isnt that big of a deal to me. I think my drivers side rubs if i make a sharp turn . who cares? This is with 165R15 tires .
Parts changing with fenderwells:
plugs - easy access
starter - not even close to the header, swap it in 10 min.
the headers can be in/out of the car in 10 minutes.
you DO have to cut some holes in the inner fender and clearance a couple spots here and there. Just get out your hammer.
Re: '69 Dart 440 Header Question [Re: Cab_Burge] #490413
10/07/09 02:58 PM
10/07/09 02:58 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Cab , how's the fit of the Mad Dogs ?
Re: '69 Dart 440 Header Question [Re: JohnRR] #490414
10/07/09 05:40 PM
10/07/09 05:40 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We use CPPA chassis headers on my sons 400 Dart and I prefer them over fenderwell on a street car anyday. His are not that bad to do if you know how to do it. And you dont have to worry about the front tires rubbing on turns like fenderwells do. Ron
Re: '69 Dart 440 Header Question [Re: 383man] #490415
10/07/09 07:16 PM
10/07/09 07:16 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
same here,
I hate high cars and little front tires. This topic has been hashed out many times. If you don't mind the above get fenderwells, if you have time make custom ones. As for the starter? i'm using the same durango one for 2 years.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: '69 Dart 440 Header Question [Re: bigtimeauto] #490416
10/07/09 07:21 PM
10/07/09 07:21 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
here are some old pics:
Re: '69 Dart 440 Header Question [Re: bigtimeauto] #490417
10/07/09 10:01 PM
10/07/09 10:01 PM
toronto
6PAK70CUDA Offline
6PAK70CUDA  Offline
toronto
Nice Dart! care to share some specs and performance numbers?
Re: '69 Dart 440 Header Question [Re: 6PAK70CUDA] #490418
10/07/09 10:19 PM
10/07/09 10:19 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Well its a whole lot different than those pics. That is the way i bought it except i put the headers on.
it ran 8.20 the other night
Re: '69 Dart 440 Header Question [Re: JohnRR] #490419
10/07/09 11:40 PM
10/07/09 11:40 PM
I sent one side back to Mad Dog to have it repaired and have not got around to putting them on the Dart yet so Soon, I hope, I'm in the middle of several projects
Re: '69 Dart 440 Header Question [Re: bigtimeauto] #490420
10/07/09 11:46 PM
10/07/09 11:46 PM
Hemiroid Offline
Hemiroid  Offline
same here,
I hate fenderwell headers. Tubes up by the master, holes in the fenderwells, no tire clearance, no thanks.
On another note, love the awesome Dart!!
Re: '69 Dart 440 Header Question [Re: bigtimeauto] #490421
10/08/09 09:58 PM
10/08/09 09:58 PM
toronto
6PAK70CUDA Offline
6PAK70CUDA  Offline
toronto
Indy heads and 500 inches I'm assuming with some N20?
Re: '69 Dart 440 Header Question [Re: 6PAK70CUDA] #490422
10/09/09 12:12 AM
10/09/09 12:12 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
I have 2" TTI headers for my Demon.
I also have an aftermarket front end, so there
shouldn't be any clearance issues here.
I didn't want to cut up my car.
Re: '69 Dart 440 Header Question [Re: 6PAK70CUDA] #490423
10/09/09 12:31 AM
10/09/09 12:31 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
No juice on my car....boost!
Re: '69 Dart 440 Header Question [Re: Hemiroid] #490424
10/09/09 12:32 AM
10/09/09 12:32 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
same here,
Thanks!
