'69 Dart 440 Header Question
#490409
10/07/09 08:20 AM
10/07/09 08:20 AM
Posts: 100 Wisconsin USA
Albert Lee
Wisconsin USA
Is TTI the only/best header for this applcation? Details: Drag Race Only, 440, Indy EZ 295 Heads, 727 Automatic, Manual Steering and Brakes, Front Motor Plate. I think I'm looking for 2" headers with an easy fit. Pictures are a big plus. Thanks in advance for your experience and suggestions! AlbertLee4@gmail.com
Re: '69 Dart 440 Header Question
[Re: Albert Lee]
#490410
10/07/09 09:18 AM
10/07/09 09:18 AM
Posts: 3,210 robin hood country
deaks
robin hood country
If you're looking for an easy fit i'd forget TTI's, my 69 440 has got them, starter access is almost nil, also, i have to take the torsion bars out, lift and tilt the motor to get them in or out. Hookers or pro parts are easier to take out but you will have to cut the inner fenders and front tyre clearance is tight with the hookers. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Cab_Burge]
#490413
10/07/09 02:58 PM
10/07/09 02:58 PM
Posts: 75,053 U.S.S.A.
JohnRR
U.S.S.A.
I like the fenderwell headers way better than the chassis headers in a A body with a BB motor. I have used a set of Pro Parts, Hookers and Hedman heads on my Duster and I now a set of Mad Dogs chassis headers for the Dart. For racing the fenderwells are way better to work on the car
Cab , how's the fit of the Mad Dogs ?
[Re: bigtimeauto]
#490417
10/07/09 10:01 PM
10/07/09 10:01 PM
Posts: 684 toronto
6PAK70CUDA
toronto
here are some old pics:
Nice Dart! care to share some specs and performance numbers?
[Re: bigtimeauto]
#490420
10/07/09 11:46 PM
10/07/09 11:46 PM
Posts: 705 Michigan
Hemiroid
We use CPPA chassis headers on my sons 400 Dart and I prefer them over fenderwell on a street car anyday. His are not that bad to do if you know how to do it. And you dont have to worry about the front tires rubbing on turns like fenderwells do. Ron
same here, I hate high cars and little front tires. This topic has been hashed out many times. If you don't mind the above get fenderwells, if you have time make custom ones. As for the starter? i'm using the same durango one for 2 years.
I hate fenderwell headers. Tubes up by the master, holes in the fenderwells, no tire clearance, no thanks.
On another note, love the awesome Dart!!
[Re: bigtimeauto]
#490421
10/08/09 09:58 PM
10/08/09 09:58 PM
Posts: 684 toronto
6PAK70CUDA
toronto
Well its a whole lot different than those pics. That is the way i bought it except i put the headers on. it ran 8.20 the other night
Indy heads and 500 inches I'm assuming with some N20?
[Re: Hemiroid]
#490424
10/09/09 12:32 AM
10/09/09 12:32 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Thanks!
BB, TT5,Procharged 3300lb Street Car 4.79/154
