V 10 stroker, anybody do one yet? #488975
10/05/09 01:47 PM
10/05/09 01:47 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline OP
On a road near you
On a road near you
9
After seeing Ron making a 500 CI small block with Ryan J got me wondering what a V 10 with a 4. plus crank would make. Im not sure if the heads would be up to par but if you could get some 360-2 made to fit the v 10 then there might be a chance at a killer combo. So does anyone know how many CI could be had by stroking a v 10 to the max????? Thanks all...Phill
Re: V 10 stroker, anybody do one yet? [Re: 9 Sec Phill] #488976
10/05/09 06:21 PM
10/05/09 06:21 PM
9
On a road near you
On a road near you
9
Nobody
Re: V 10 stroker, anybody do one yet? [Re: 9 Sec Phill] #488977
10/05/09 07:25 PM
10/05/09 07:25 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I want to see a 14/71 blower atop a V-10 with mechanical injection
Re: V 10 stroker, anybody do one yet? [Re: 9 Sec Phill] #488978
10/05/09 08:30 PM
10/05/09 08:30 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
well, max bore will probably be 4.03 or 4.06. max stroke would be the same as any LA stroker, probably 4.125 or so...would be 526CID....but then you're talking custom billet crank, and you're limited to truck or viper heads...
2017 Grand Cherokee Overland
Re: V 10 stroker, anybody do one yet? [Re: patrick] #488979
10/06/09 12:32 AM
10/06/09 12:32 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Every one says they are based off the 360 but I never see the resemblence in any of the motors I have been involved in either truck or viper. They have a dry valley and very different bottom ends, I think they have less clearance than a SB just by eyeballing it.
You would need a custom billit crank and I have heard of a couple in the 4in range but not much more. I think most guys just want billit because they run 2 turbos on em and nitrous and ...
I don't know what the viper heads flow but they look way better than a truck head
Re: V 10 stroker, anybody do one yet? [Re: HotRodDave] #488980
10/06/09 02:04 AM
10/06/09 02:04 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
I agree with what has been said.The good..valve train (no LA lifter angle) and lite weight assy.The bad...it's Heavy (800 lbs+)and an odd fire engine. Viper cyl heads are the way to go. Forget the iron heads. The real problem with them is getting the oil back to the pan.There are no oil drains at the rear of the cyl head.The Hi-po version of the iron engine(never released)ran into oil press problems at only 4800 rpm. Some was due to the lack of a windage tray and the shallow oil pan. Some was due to the huge amount of oil trapped in the cyl head.All that aside I think a similar build (w/more camshaft& c.i.)to the Lemans Viper could make 800 h.p without being on kill in a Drag race mode.The engine responds well to mods as long as those issues are addressed.Rod Hall ran one (stock displacement) (maybe 650h.p.)in his off road Dodge truck.
Leave the gun.......take the Cannoli's....Mike
Post deleted by Defbob [Re: Defbob] #488981
10/06/09 08:48 AM
10/06/09 08:48 AM
Re: V 10 stroker, anybody do one yet? #488982
10/06/09 08:53 AM
10/06/09 08:53 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
A popular cubic inch is 522 with the Viper and SRT Ram guys. Stryker makes some good heads for them.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: V 10 stroker, anybody do one yet? [Re: 67HEMI] #488983
10/06/09 09:49 AM
10/06/09 09:49 AM
McCandlessboy Offline
I have a TT viper. I never take it over 6k rpms. The oil system is the big weakness. Should have probably done a dry sump, but didn't at the time. This is probably the most turbo friendly application ever for a dodge.
