Trans cooler circuit #488133
10/04/09 04:11 PM
10/04/09 04:11 PM
Milwaukee WI
TRENDZ Offline OP
TRENDZ  Offline OP
Milwaukee WI
Anybody out there know what the normal trans cooler pressure would/ should be at idle? I'm also wondering what it would be at higher rpm.
Re: Trans cooler circuit [Re: TRENDZ] #488134
10/04/09 09:19 PM
10/04/09 09:19 PM
I have never measured it but I remember around 3 to 7 lbs as the amount of pressure on them, not much I have removed one side to drain some fluid out by starting the motor, it doesn't comeout real fast It doesn't seem to be under very much pressure
