what gear for 2800lbs 850 hp car?
#487927
10/04/09 12:58 PM
10/04/09 12:58 PM
Posts: 2,128 sweden
sshemi
sweden
Re: what gear for 2800lbs 850 hp car?
[Re: sshemi]
#487928
10/04/09 01:06 PM
10/04/09 01:06 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
More info, where you make power, the rest of the combo trans and such would help..FWIW my Hemi was in that power range with a 33" tire and a glide and I ran a 4.30. Car went 8.70's at 155ish that way and I crossed the stripe at 7050. Oh yeah mine was 2920 with me and the Hemi on board.
[Re: sshemi]
#487930
10/04/09 01:27 PM
10/04/09 01:27 PM
Al_Alguire
Las Vegas
Then 4.30 sounds like a good choice to me.
[Re: mr2performance]
#487933
10/04/09 01:40 PM
10/04/09 01:40 PM
Al_Alguire
Las Vegas
I was thinking with the TF a .30 might be a better choice. But if you were thinking like a super stock racer then 4.88 might be better, the car will likely be quicker with it, just no as much MPH..Must be the bracket racer in me again.
[Re: sshemi]
#487935
10/04/09 02:40 PM
10/04/09 02:40 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I'm likely leaving a little bit on the table, I run a 4.10 with a 33" tire. 3000#, 850 hp. I stayed with the 4.10 since I hope to hit it with a little spray in the future. It's done a best of 1.25 sixty but more typical is 1.28 or 1.29 I took out 4.56's when I put in the new motor so I never tried it with any other gear. I have no suggestions since I've never tried any other gear, just providing info as a point of reference.
[Re: MegaDart]
#487939
10/05/09 08:12 AM
10/05/09 08:12 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I run a 4.56, 33.6 tall tire, torqueflite, 3000lb car, cross at 7400 rpm. Max hp at 6900 to 7000 rpm. I have 440-1 heads, so power is likely to fall off quicker than a hemi?
