Just Bench Racin'/ Hot Rod Mag 383 Build #486396
10/02/09 06:33 PM
10/02/09 06:33 PM
Mid-Ohio
Bakaruda432 Offline OP
mopar addict
mopar addict
Mid-Ohio
I found an old copy of Hot Rod Magazine in storage and the house.
It had an article which was 1 of 3 about a Hot Rodded 383 Mopar engine.
It had ported 906 heads,+.060 Bore Pistons 10.3:1 CR,stock rods/ crank, Comp Cams 239/247 at .050 .573/597 inch lift 1.6:1 rocker rollers.
With an Edelbrock Torker 383 intake and an 850 Holley it made 456 Lb-FT of Torque at 4,900 rpm and 457 HP at 5,900.(394 CID)
Would this engines output be vastly improved with 11.25-12:1 CR and a 413/440 with resized 383/400 size mains (3.75 inch), 6.76 413/440 Rods, Aluminum entry level heads same cam/intake/carb (438 CID)?
Would using a 3.90 crank for the 400 help more (455 CID)?
What do you guys/gals think?
Re: Just Bench Racin'/ Hot Rod Mag 383 Build [Re: Bakaruda432] #486397
10/02/09 07:16 PM
10/02/09 07:16 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
1. yes.
2. yes.
Re: Just Bench Racin'/ Hot Rod Mag 383 Build [Re: RemCharger] #486398
10/02/09 07:28 PM
10/02/09 07:28 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Ofcourse the bigger ci motor is better but if you are just talking about a 383..stock stroke those are decent numbers. I think it would be hard to improve on them with a set of Eddies or stealths OOTB. 383s are kinda the forgotten motor, the 440's little brother that is often overlooked...but they could really scream if set up right.
Re: Just Bench Racin'/ Hot Rod Mag 383 Build [Re: Bakaruda432] #486399
10/03/09 09:27 AM
10/03/09 09:27 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I've been building the combo I bolded forever now with a +.030 overbore, to get 12.5 you need a net, including valve reliefs, 10cc dome on your piston with 82 cc chamber 906's. To do the build you are speaking of will require a custom piston Take that Hotrod HP figure with a grain of salt. If it's the article that gets posted up all the time it was done on a dyno in southern california that was later found out to be HAPPY , though most with half a clue KNEW the numbers were off, the numbers were inflated. Unless you are tripping over 383's, like myself, start your build with a 400 block and don't use open chamber iron heads .
Re: Just Bench Racin'/ Hot Rod Mag 383 Build [Re: JohnRR] #486400
10/03/09 10:06 AM
10/03/09 10:06 AM
Mid-Ohio
mopar addict
mopar addict
Mid-Ohio
It seems like here in North-Central Ohio 383/400s are really easy to find but then again so are 413s.
I have read the last post and then reread it as well as 440 Sources Stroker Kits.
It seems a like a single plane or tunnel ram 438 or 455 with either max ported 906/452 or CNC ported Stealth aluminum heads would have to be really fun in a light weight '27 T roadster or '32 5W Ford coupe.
