I found an old copy of Hot Rod Magazine in storage and the house.
It had an article which was 1 of 3 about a Hot Rodded 383 Mopar engine.
It had ported 906 heads,+.060 Bore Pistons 10.3:1 CR,stock rods/ crank, Comp Cams 239/247 at .050 .573/597 inch lift 1.6:1 rocker rollers.
With an Edelbrock Torker 383 intake and an 850 Holley it made 456 Lb-FT of Torque at 4,900 rpm and 457 HP at 5,900.(394 CID)
Would this engines output be vastly improved with 11.25-12:1 CR and a 413/440 with resized 383/400 size mains (3.75 inch), 6.76 413/440 Rods, Aluminum entry level heads same cam/intake/carb (438 CID)?
Would using a 3.90 crank for the 400 help more (455 CID)?
What do you guys/gals think?
