01 PT Cruiser - replace light switch #485260
10/01/09 03:41 PM
10/01/09 03:41 PM
Aurora, Oh.
max_maniac Online happy OP
max_maniac  Online Happy OP
Aurora, Oh.
On the wife's 01 Cruiser she is starting to have issues getting the headlights to come on. I'm guessing it's in the switch on the column. All other lights work and if I play with it enough I can sometimes get the reg headlights on. The brights and the fog lights work all the time Has anyone relaced this switch and how hard of a job is it or do I take it to the dealer and get ripped
Thanks --------
Russ
Re: 01 PT Cruiser - replace light switch [Re: max_maniac] #485261
10/01/09 04:44 PM
10/01/09 04:44 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I replaced the multifunction switch on my 04 when I upgraded to foglights.
It's not bad at all, remove the column covers, disconnect the wiring connectors and a couple screws IIRC.
You can try removing it and spraying the thing down with contact cleaner (Radio Shack).
Price out the switch and the fog light kit. The kit wasn't too bad, and they may be higher on just the switch. That way, you have spare lights.
Re: 01 PT Cruiser - replace light switch [Re: max_maniac] #485262
10/02/09 07:31 AM
10/02/09 07:31 AM
On the open road
Hrtbkr Offline
Hrtbkr  Offline
On the open road
Not to hijack the thread, but...
The fog lights on my wife's '03 will not shut off. The dealer said it was a short in the multifunction switch, but the switch is on back order and may not be available for some time. And then I was charged $47 to be told they can't fix my car
Anyway, does anyone have a source for these switches?
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: 01 PT Cruiser - replace light switch [Re: Hrtbkr] #485263
10/02/09 10:04 AM
10/02/09 10:04 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Any good parts store has them.The non fog light switch is actually more than the fog light one.Rocky
Chrysler Firepower
Re: 01 PT Cruiser - replace light switch [Re: therocks] #485264
10/02/09 10:48 AM
10/02/09 10:48 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Rock auto
2002 CHRYSLER PT CRUISER 2.4L 2429cc 148cid L4 FI (B) : Electrical-Switch & Relay : Turn Signal Switch Price Core Total $99.79 $0.00 $99.79
OE PRO Part # SM144
w/o Fog Lamps
OE PRO Part # SM147
w/ Fog Lamps
* Non-stock item--shipping delayed up to 31 business days
$79.99 $0.00 $79.99
So it's like they said, the fog light one is cheaper, but back ordered.
Re: 01 PT Cruiser - replace light switch [Re: RodStRace] #485265
10/02/09 02:47 PM
10/02/09 02:47 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Try Advanced or a major store.Just because one is out dosent mean they all are.Rocky
Chrysler Firepower
Re: 01 PT Cruiser - replace light switch [Re: therocks] #485266
10/17/09 09:50 AM
10/17/09 09:50 AM
Aurora, Oh.
Aurora, Oh.
One last question - do you have to remove the air bag to get to the multifunction switch? I really don't want to mess with something like that if I don't have to. Thanks.
Russ
Re: 01 PT Cruiser - replace light switch [Re: max_maniac] #485267
10/17/09 10:04 AM
10/17/09 10:04 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
No. the steering wheel and the air bag are not disturbed.
Where did you get the switch?
Re: 01 PT Cruiser - replace light switch UPDATE [Re: RodStRace] #485268
10/17/09 10:31 AM
10/17/09 10:31 AM
Aurora, Oh.
Aurora, Oh.
Finally got to this lil project and took the multifunction switch off the column. I cleaned off the electrical connections on the plug and put it back together and the lights started working. Put it all together and they were ok for a few times and stopped again. Then I just wiggled the wires where the plug is on the back and they started working again. The switch itself is not bad but the electrical connection is not consistant so I'll see what I can do with that.
Russ
