500 ci. #485240
10/01/09 03:39 PM
10/01/09 03:39 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
Hey Fellows.... this is my 1st post here. great site! I have a question for the 500ci guys. I'm taking our new motor to the track for the 1st time tomorrow night. This is our 1st 500, always ran 440's. Question is... what rpm should I look to shift this thing? It's a 4.15 stroked 440+.03, roughly 12.7:1 comp., .690 comp roller 286@ .050 dur., indy ez's flow 330in 230ex, 3400 lb cuda 5000 converter. thanks
Re: 500 ci. [Re: JACK1440] #485241
10/01/09 03:42 PM
10/01/09 03:42 PM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
start at 6500 and go up from there
Re: 500 ci. [Re: challenger1320] #485242
10/01/09 03:45 PM
10/01/09 03:45 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
That whole setup sounds real close to mine. I shift mine at 6800, but to be honest I hadn't tried many other shift points.
Re: 500 ci. [Re: JACK1440] #485243
10/01/09 03:46 PM
10/01/09 03:46 PM
organ
maximum entropy Offline
organ
first of all- greetings and salutations. that combo should go perty good. a lot o' duration. maybe start at 7000 and experiment from there? you could prolly shift at 6500 and go as fast- you'll know after experimentation. hopefully we'll get the experts to chime in?
Re: 500 ci. [Re: challenger1320] #485244
10/01/09 03:46 PM
10/01/09 03:46 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Sounds similar to my combo except I have a little more compression. I shift mine at 6700 so you should start around 6400 and go up 500 from there on every run until you find what it likes
Russ
Re: 500 ci. [Re: max_maniac] #485245
10/01/09 03:51 PM
10/01/09 03:51 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
thanks guys... some good advice. I'll be back on Saturday morning with the results. I'd like to see 10.20's.
Re: 500 ci. [Re: JACK1440] #485246
10/01/09 04:03 PM
10/01/09 04:03 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I got nothing to add but
Re: 500 ci. [Re: JACK1440] #485247
10/01/09 05:49 PM
10/01/09 05:49 PM
AndyF Offline
AndyF  Offline
Max Wedge port size or standard port size? 1000 rpm difference between the torque curves depending on port size.
That is a ton of duration on the camshaft. My 505 motor made over 800 hp running only 266 at 050 duration on the intake side. Not sure what it would've done with another 20 degrees, never tried that much before.
Re: 500 ci. [Re: AndyF] #485248
10/01/09 07:41 PM
10/01/09 07:41 PM
my 500 i shift at 6400 rpm, anything over that and i slow down a few hundreds.
Re: 500 ci. [Re: JACK1440] #485249
10/01/09 07:46 PM
10/01/09 07:46 PM
NC
440Jim Offline
440Jim  Offline
NC
It might like higher, but I would start at 6500 and work up; due to the head flow. If they flowed more, then 7000 may be closer to ideal. That cam should support even higher, but as I said... head flow at that CID.
Re: 500 ci. [Re: JACK1440] #485250
10/01/09 08:22 PM
10/01/09 08:22 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Tell us more about your setup, intake, headers, rear gear,carb.
The little old lady from Pasadena is back!
Re: 500 ci. [Re: Barnstorm] #485251
10/01/09 08:35 PM
10/01/09 08:35 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
500ci with very similar cam and comp. as you except 440-1s @ about 360cfm, with a 9375.
Best runs were 7000 on the 1-2, 7200 on the 2-3 and cross 72-7300.
Re: 500 ci. [Re: jim sciortino] #485252
10/01/09 11:25 PM
10/01/09 11:25 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Just wanted to say "Hi" Jack as I work with your dad. I started a month ago and I am working right next to him. I have known your dad for at least 6 years as I met him at the local cruise nights. I used to have a Dart but now have this red 63. I saw the new eng when he was putting it together in the shop. Looks like a very strong setup. Your dad is about the nicest guy I have known and I couldn't have asked to work next to a nicer guy. I hear you will be going to Capital and I wish you guys the best of luck tomorrow. Ron
Re: 500 ci. [Re: 383man] #485253
10/02/09 12:35 PM
10/02/09 12:35 PM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
thanks Ron... My dad is my best bud. a wealth of knowledge when it comes to mopar. he worked on these things when they were new. Are you going to the nosalgia drags next week at capitol? if so, we need to get a spot in the pits together.
to answer Barnstormer: the car has a single 1050 dominator, 2" primary headers and 4:88 dana. max-wedge ports on the indy's.
Re: 500 ci. [Re: JACK1440] #485254
10/02/09 03:36 PM
10/02/09 03:36 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Plenty of carb, header and gear, converter. You might take it over 7000 if you like your valvetrain. Typical first time out, see what it likes for jet, traction etc. Nice combo..let us know.
Re: 500 ci. [Re: JACK1440] #485255
10/03/09 03:32 AM
10/03/09 03:32 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I might go to Capital as my brother is going with his 64 Ply so I may go to have fun with you all. Ron
Re: 500 ci. [Re: 383man] #485256
10/03/09 09:31 AM
10/03/09 09:31 AM
MD
JACK1440 Offline OP
JACK1440  Offline OP
MD
well... another one of thoses nights at the track when you tell yourself i should've stayed home..... 1st we had to fix a trans cooler leak that decided to start when we got the track and not at home. Then I took our 1st pass and the car felt very flat. ended up running an 11.04 but, I shifted it a low 6000 rpm due to it being a brand new motor with no runs. Just wanted to give a little break in. Anyways... got her back to the pits and noticed that the volt meter read only 10 volts. Turns out I had one of the alternator wires pop off. probaly when I was in the water box. So, we fixed that up and headed back to the staging lanes only to watch a mustang oil the whole track down.... Sat waitng another 45 mins. for track clean-up only to be greeted with mother nature's rain.. loaded her up and went home. UUGGGHHHH!
Re: 500 ci. [Re: JACK1440] #485257
10/03/09 10:42 AM
10/03/09 10:42 AM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
Don't worry...you'll get all the bugs out of her. Better off finding them now then during eliminations at some time down the road....
71 440-6 4spd & 69 Hemi 4spd
Re: 500 ci. [Re: JACK1440] #485258
10/03/09 10:44 AM
10/03/09 10:44 AM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
Welcome to the board. Your engine should make peak power 7000-7200 RPM atleast all the 500CI engines we do with Indy Heads and a solid roller end up at. Shift it 7200 ish and cross the strip 7800 for the best ET. The converter is tighter than I would like but its a start.
Re: 500 ci. [Re: PETE@BESTMACHINE] #485259
10/03/09 10:53 AM
10/03/09 10:53 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Sorry to hijack the thread, just wondered Pete if a motor shifting that high would require an external oiling system.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
