What to Fill small drill holes with.. #484934
10/01/09 07:18 AM
10/01/09 07:18 AM
usa
mrmopardan Offline OP
usa
I am cleaning up things under the hood getting ready for cruzin the coast next week. I have about 10 small drill holes I want to quickly fill & touchup paint with a tiny brush. Other than Bondo, what works well for filling theses 1/8" drill holes ? Thanks
68 GTX Full street trim, solid lifter cammed. Best 11.34 @ 121 mph. 1.72 60 ft. (yeah I know.. my 60 ft. sucks)
Re: What to Fill small drill holes with.. [Re: mrmopardan] #484935
10/01/09 07:23 AM
10/01/09 07:23 AM
NY usa
540challenger Offline
NY usa
If you access to a welder i would fill them in with weld and just grind them flat.
Re: What to Fill small drill holes with.. [Re: 540challenger] #484936
10/01/09 08:02 AM
10/01/09 08:02 AM
usa
usa
No welder. Looking for other methods.
Re: What to Fill small drill holes with.. [Re: mrmopardan] #484937
10/01/09 08:04 AM
10/01/09 08:04 AM
NJ
440challenger Offline
NJ
jb weld?
Re: What to Fill small drill holes with.. [Re: 440challenger] #484938
10/01/09 08:40 AM
10/01/09 08:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
jb weld?
Re: What to Fill small drill holes with.. [Re: JohnRR] #484939
10/01/09 08:50 AM
10/01/09 08:50 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
A soldering gun and a little solder will fix it right up.
NMCA NSS 67 Coronet
Re: What to Fill small drill holes with.. [Re: Barry70GTX] #484940
10/01/09 08:53 AM
10/01/09 08:53 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Be like the tuners and put LED's in them.
Re: What to Fill small drill holes with.. [Re: Commando1] #484941
10/01/09 09:19 AM
10/01/09 09:19 AM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Get some short set screws with some JB Weld on them. Screw them in and grind flat after epoxy dries.
Re: What to Fill small drill holes with.. [Re: maximus] #484942
10/01/09 09:36 AM
10/01/09 09:36 AM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
Just throw a rag over the carb and everybody will look at it and wonder what you are hiding and no one will notice the holes.
Re: What to Fill small drill holes with.. [Re: Barry70GTX] #484943
10/01/09 11:29 AM
10/01/09 11:29 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I've done this in the past with my Weller soldering iron and rosin core solder. It helps if you take a larger drill bit and chamfer the holes slightly.
Re: What to Fill small drill holes with.. [Re: 6PakBee] #484944
10/01/09 11:48 AM
10/01/09 11:48 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I don't like the solder idea ... the flux will rot the surrounding steel in no time unless you can clean it of both sides - not a possibility if the holes are in a frame rail.
Re: What to Fill small drill holes with.. [Re: Stanton] #484945
10/01/09 12:35 PM
10/01/09 12:35 PM
usa
usa
I'll try the JB Weld first. Thanks guys
(then I'll try the LED lights.LMAO!! )
Re: What to Fill small drill holes with.. [Re: mrmopardan] #484946
10/01/09 12:37 PM
10/01/09 12:37 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
3m paintable seam sealer from auto paint store i just used it in my engine compartment and touched it up looks good dan
Re: What to Fill small drill holes with.. [Re: mrmopardan] #484947
10/01/09 01:28 PM
10/01/09 01:28 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
Body guy told me to user panel bond (two part adhesive). The stuff used to glue on replacement panels.
Re: What to Fill small drill holes with.. [Re: Stanton] #484948
10/03/09 09:54 AM
10/03/09 09:54 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Rosin core, rosin core, not acid core. Rosin core is for electrical work specifically to prevent flux corrosion at a soldered joint.
Re: What to Fill small drill holes with.. [Re: srunge55] #484949
10/03/09 12:24 PM
10/03/09 12:24 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I used that stuff on my grill and it's great. dries to the perfect consistency for sanding... though jb weld might work better here.
I get the feeling that the OP needs a method on an already painted engine bay because he said he wants to touch it up with a brush..... to me that means that anything with a welder or sanding it out.
Re: What to Fill small drill holes with.. [Re: Stanton] #484950
10/03/09 12:35 PM
10/03/09 12:35 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
This guy soldered up his firewall.... See what can happen!!!
