Help me to the 10s
#484135
09/30/09 01:21 PM
09/30/09 01:21 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Wondering what it would take to get my pig into the 10s. Combo is a 3800lb 72 B-body, 448 10.5 to 1 comp, ported 452s, (no flow numbers but Id bet they are around 260@.600) M1 w/2 inch open spacer, 2 inch hookers, cam is a Comp solid TL288, 259/259 .550 lift, .585 with the 1.58 rockers Im using, 108CL, in at 101.5. 950HP, running on E85. Converter flashed right at 5k, maybe more like 4900. 4.30 gear with 275/60/15 ET radials. So far my best ET/MPH is in my sig. I know its got more in it as it sits with more tuning. But, lets assume that my sig performance is as good as it gets. IM using 3 inch into Eddy RPM mufflers into 2.5 tailpipes, no X or H pipe. Im thinking with the cam specs, lack of crossover, and the 2.5 tailpipes I might see .1 or more with the pipes open. Ive got a comp 266,.646 roller that I could swap in, not sure if 266 will be OK with only 10.5 compression?? Ive also got a Meziere water pump to throw on also. I converted the car to E85 over last winter. I dont have any 1/4 mile passes since converting, but I took it to an 1/8 mile track early this summer. FWIW, the numbers converted to a 11.34@ 118.25 My best 1/4 numbers were in 600DA air and the 1/8 mile passes were in 2600DA air, so I hope to pick up there also. Any ideas?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Help me to the 10s
[Re: Von]
#484136
09/30/09 01:43 PM
09/30/09 01:43 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Von, if your running a belt driven water pump and you convert to the electric it will pick up some, Abbey's car picked up over 2 tenths.
I bet you can get a 10.99 pass what what you have by moving to the electric water pump, open headers (if you can pull the exhaust and muffler off the car to save the weight that would be best) and your switch to e85. I think all this combined with some good air at Tulsa will get you a ten second slip.
All the little things add up.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: Von]
#484137
09/30/09 01:47 PM
09/30/09 01:47 PM
Posts: 4,152 SO. CAL.
70blackfish
SO. CAL.
to me your converter stall is to high, you need to try to lighten your car up. I would say loose the exhaust at the track.
if it were me I would call Dwayne Porter. @ porter racing heads or fast68plymouth on this board. that roller cam sounds good but your heads and compression arent right for it.
[Re: 70blackfish]
#484138
09/30/09 02:06 PM
09/30/09 02:06 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
An electric water pump setup will be worth 2 tenths or so. You can try open headers, but I doubt it'll make much difference. If you remove the system from the car it will likely go faster just from the weight reduction. An X pipe will increase power at the expense of sound quality. I just don't care for the sound of an X pipe. Change those things and do a little more tuning and you should be into the 10s. After that, the next thing I'd be doing is a head swap. CHIP
[Re: an8sec70cuda]
#484139
09/30/09 05:12 PM
09/30/09 05:12 PM
Von
NE Oklahoma
Thanks for the responses so far. On the roller cam I have, Dwayne spec'd that cam for a BS head 470 that I have, but havent put in the car yet. Not sure I understand how the cam is "wrong" for the 452 heads. As far as compression goes that is why Im asking the question. A certain board member has a certain Challenger that has a 10.8 to 1 446 with a flat tappet cam that is [Email]266@.050[/Email], a tick less converter, and a tick less gear and the same weight. 'Course this certain Challenger 60s and ETs pretty dang good. So, isnt 10.8 with aluminum heads more like 9.8 or so with iron heads? See what Im getting at?? I have no problem having a roller ground with around 260 duration, but Im not so sure the one I have wont work? On the converter, I dont "think" its too much flash speed. I had a 9 inch in it at first that flashed right at 4100-4200. I picked up .16 going to this converter. Its not some mushy race only piece. Slip figures out to 7 percent and drives like a dream on the street. On the car weight, no way, no dice, no anything its losing anymore weight. Ive cut 150-175 lbs off it (glass hood, manual steering, aluminum this, that,etc) and I refuse to pull interior out, gut this, gut that etc. Its a freakin street car. Im hoping to pick up with the open pipes based on a conversation with Dwayne. When he ground the 266 roller for me he said it should run better with no exhaust vs. closed exhaust due to not being a split duration, ie more duration on the exhaust side. Since the current flat tappet is not a split, Id hope/figure the results would be the same. Keep em coming I do appreciate the input.
[Re: Von]
#484140
10/01/09 03:14 PM
10/01/09 03:14 PM
Von
NE Oklahoma
[Re: Von]
#484141
10/04/09 10:55 PM
10/04/09 10:55 PM
BradH
... A certain board member has a certain Challenger that has a 10.8 to 1 452 with a flat tappet cam that is [Email]266@.050[/Email], a tick less converter, and a tick less gear and the same weight. 'Course this certain Challenger 60s and ETs pretty dang good.
Small correction made to the above info... assuming you're actually talking about my car.
[Re: BradH]
#484142
10/04/09 11:05 PM
10/04/09 11:05 PM
Posts: 5,618 long island NY
Ari440
long island NY
open pipes 3.5 collecters 18 inchs long
with the 4.30 gears use a 295 or 29.5 10.5 slick
any pics of your car ?
1.39 9.85 - 137 mph
[Re: Ari440]
#484143
10/05/09 07:56 AM
10/05/09 07:56 AM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The roller and electric water pump, combined with a free flowing (maybe open?) exhaust will really wake this car up IMHO. A set of standard port aluminum heads, cut to increase compression and make serious use of the e85 will make it an animal with the other changes is place.
[Re: Von]
#484144
10/05/09 08:38 AM
10/05/09 08:38 AM
Posts: 205 Chicago,Illinois
nosboy
Chicago,Illinois
Personally, I think the 4.30 gear is KILLING YOU!!! Yes, 3800 is a LOT for a racecar and your 60's must really suck,,,but,,, I think a 4.88 gear would help tremendously!!!
