Braided trans lines? #484007
09/30/09 08:41 AM
09/30/09 08:41 AM
KY
juicedcuda Offline OP
KY
Is it okay to use an fittings and steel braided line for the trans to cooler lines?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: Braided trans lines? [Re: juicedcuda] #484008
09/30/09 08:49 AM
09/30/09 08:49 AM
ky
68roadrunner Offline
ky
yes an #6
Re: Braided trans lines? [Re: 68roadrunner] #484009
09/30/09 08:55 AM
09/30/09 08:55 AM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
That's all I've ever used. I also only use teflon rather than rubber (as the hose within the steel braiding) to prevent deterioration over the years that could cause break down and end up with with trash in the lines.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Braided trans lines? [Re: 68roadrunner] #484010
09/30/09 09:26 AM
09/30/09 09:26 AM
KY
KY
yes an #6
the fittings on the cooler and trans are -4, is that going to be okay?
Re: Braided trans lines? [Re: juicedcuda] #484011
09/30/09 09:34 AM
09/30/09 09:34 AM
NY usa
540challenger Offline
NY usa
yes an #6
you should be fine #4 = 5/16 which is the stock size.
#6 is 3/8 which is a nice upgrade but the stock fittings in the trans are very small already 1/8 npt and imo need to be enlarged to get the added benefit of the bigger line.
Re: Braided trans lines? [Re: 540challenger] #484012
09/30/09 10:20 AM
09/30/09 10:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
yes an #6
I use #6 line but I use a AN#6 to 1/8 fitting but I
drill the fitting out a little for better flow(dont
go crazy drilling it out... gets weak)
Re: Braided trans lines? [Re: MR_P_BODY] #484013
09/30/09 11:37 AM
09/30/09 11:37 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
im not saying it is or isn't OK that's what i've used but i do know ATI doesn't want you using it they want teflon. if they find out you've used rubber it will void any warranty
Re: Braided trans lines? [Re: jamesc] #484014
09/30/09 12:46 PM
09/30/09 12:46 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
5/16" is actually -5AN. I have used -6 to -5 adapters and hardware to connect -6 flex lines to OEM type 5/16 steel tubing. IMO, -4 is too small. I prefer -6 teflon.
Re: Braided trans lines? [Re: CMcAllister] #484015
09/30/09 01:15 PM
09/30/09 01:15 PM
NY usa
NY usa
He is right i was mistaken
here is a chart
http://www.russellperformance.com/misc/tech/main.shtml
