Braided trans lines?
#484007
09/30/09 08:41 AM
09/30/09 08:41 AM
Posts: 761 KY
juicedcuda
KY
Is it okay to use an fittings and steel braided line for the trans to cooler lines?
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
Re: Braided trans lines?
[Re: 68roadrunner]
#484009
09/30/09 08:55 AM
09/30/09 08:55 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
That's all I've ever used. I also only use teflon rather than rubber (as the hose within the steel braiding) to prevent deterioration over the years that could cause break down and end up with with trash in the lines.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: juicedcuda]
#484011
09/30/09 09:34 AM
09/30/09 09:34 AM
Posts: 2,826 NY usa
540challenger
NY usa
yes an #6
the fittings on the cooler and trans are -4, is that going to be okay?
you should be fine #4 = 5/16 which is the stock size.
#6 is 3/8 which is a nice upgrade but the stock fittings in the trans are very small already 1/8 npt and imo need to be enlarged to get the added benefit of the bigger line.
[Re: 540challenger]
#484012
09/30/09 10:20 AM
09/30/09 10:20 AM
Posts: 52,972 Romeo MI
MR_P_BODY
yes an #6
I use #6 line but I use a AN#6 to 1/8 fitting but I drill the fitting out a little for better flow(dont go crazy drilling it out... gets weak)
[Re: jamesc]
#484014
09/30/09 12:46 PM
09/30/09 12:46 PM
Posts: 11,706 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
5/16" is actually -5AN. I have used -6 to -5 adapters and hardware to connect -6 flex lines to OEM type 5/16 steel tubing. IMO, -4 is too small. I prefer -6 teflon.
