Re: Found my oil pressure problem, Thanks guys
[Re: galen]
#483955
09/30/09 10:38 AM
09/30/09 10:38 AM
Posts: 52,972 Romeo MI
MR_P_BODY
After checking everything I could think of, Decided to pull the plunger out of my new single line pickup cover. The cap was loose. I had the cover off to deburr and check the pump and never pulled the plunger. Had to read the meaning of "assume" again. Long story short, sucking air around the cap. Oil pressure went from 30-35 fluctuating at idle, 80 dropping to 60 above 3500. to 40 steady idle and 80 steady above 3500. Cut open my second break in oil filter after changing to Wix. And it is clean . First drive this weekend. Galen
Good catch
[Re: galen]
#483956
09/30/09 12:30 PM
09/30/09 12:30 PM
Posts: 43,141 Bend,OR USA
Cab_Burge
Assuming has killed a lot of parts, both race and street parts on Hi Po applications We all have to learn that one part or job at a time Good detective work diligence pays off
