timing needs set on magnum v8 #483884
09/29/09 10:14 PM
09/29/09 10:14 PM
Ohio
P
pengwin Offline OP
pengwin  Offline OP
P
Ohio
just got a good deal on 95 5.2 Ram, but engine seems to idle rough and gas mileage really bad. After some trouble shooting I checked the timing and it's way off. I tried dialing it in by rotating the distributor but it didn't seem to change anything. How do I set the timing on this?
Re: timing needs set on magnum v8 [Re: pengwin] #483885
09/29/09 10:27 PM
09/29/09 10:27 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
You don't.Timing is controlled by the ECU. Rotating the distributor just causes new problems. Check for codes,look for oil on the spark plugs and inside the intake manifold.Lots of possible issues.first check for codes.
Re: timing needs set on magnum v8 [Re: pengwin] #483886
09/29/09 10:28 PM
09/29/09 10:28 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You dont. The distributor needs to be set up for the correct sync signal. All timing is done through the computer. Getting a fsm will show you how to set it.
Re: timing needs set on magnum v8 [Re: NITROUSN] #483887
09/29/09 10:38 PM
09/29/09 10:38 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
You can put the motor on TDC pull the cap and line up the rotor with the notch in the cam sensor plate and it should be very close. You can get it closer with a good scanner.
Like was said you need to see if there are any codes, if no codes pull the plugs and check them out, also need to check the wires real good, if they look old or cheap replace them.
