1942 dodge butterfly hood #483823
09/29/09 09:41 PM
09/29/09 09:41 PM
toledo ohio
P
pitbovver Offline OP
P
toledo ohio
I found a 1941 plymouth hood locally for cheap. Does anybody know if this will fit on the dodge. I remember something in the differences btw the brands size wise and stylistically the plymouth hood is one unit opening from a firewall hinge?
Re: 1942 dodge butterfly hood [Re: pitbovver] #483824
09/29/09 11:53 PM
09/29/09 11:53 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The whole front will need changed.I have a 41 Plymouth sitting
The grill and fenders are definetly different.Yes the 41 opens from the firewall side.What is cheap for the hood?Rocky
Chrysler Firepower
Re: 1942 dodge butterfly hood [Re: therocks] #483825
09/30/09 01:25 AM
09/30/09 01:25 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
in 1940 the canadian dodge used plymouth sheet metal all except the grille area,,,but that 42 looks kool
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: 1942 dodge butterfly hood [Re: therocks] #483826
09/30/09 12:44 PM
09/30/09 12:44 PM
toledo ohio
P
P
toledo ohio
25 bucks for an unfinished one and 50 for a painted one....My grill and frontend have been modified by a P.O. with 1x1 aluminum square tube stock.
I am not a big fan of the butterfly hood and am looking at different options in order to get into the engine compartment. Has anyone welded up and decked a butterfly hood? I was thinking the Plymouth would fit fairly nice with a little bit of fanagling. If it is narrower then I would think it would be easier to weld up the og hood instead of adding to a plymouth hood.....Any ideas?
Re: 1942 dodge butterfly hood [Re: fstfish66] #483827
09/30/09 01:52 PM
09/30/09 01:52 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
Oh really? I need pictures!!
I have a 1940 Dodge Coupe that I'm looking for a hood for, maybe this will give me another option.
Re: 1942 dodge butterfly hood [Re: pitbovver] #483828
09/30/09 01:56 PM
09/30/09 01:56 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
wonder if the 41 plymouth front end would fit your 42 dodge?? or a 42 ply front end,,but that may be hard to locate,,
may be easier to shorten your hood from front to back and make it like a 40 dodge hood then weld it in to one piece,,and figure out hinges,,
or make it open from one side or the other like a 50 buick does ,,weld it from undernieth or make a frame undernieth and keep the center hood trim making it look orignal from the out side,if the 41 ply front end would fit,that would be what i would do,unless you perfer the 42 dodge sheet metal,,it is more rare,yours is the first 42 dodge ive ever seen,,41 ply,s are sotra common. just mt .02 cents
2015 cherokee
2013 R/T classic
Re: 1942 dodge butterfly hood [Re: rabid scott] #483829
09/30/09 02:02 PM
09/30/09 02:02 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
the american 40 dodge hood is only 3/4 as long front to back as the canadian,,,the canadian hood is full length from fire wall to almost the grille,,the canadian dodge uses plymouth sheet metal,,all except for the grille center mount,,, i am goig to try to post pics of both,,the blue car is american,,the copper is canadian,,,if not pics e mail me ill e mail them you fstfish66@aol.com
2015 cherokee
2013 R/T classic
Re: 1942 dodge butterfly hood [Re: fstfish66] #483830
09/30/09 02:06 PM
09/30/09 02:06 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
pics i hope both hoods are butterfly
2015 cherokee
2013 R/T classic
Re: 1942 dodge butterfly hood [Re: fstfish66] #483831
09/30/09 02:09 PM
09/30/09 02:09 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
40 american my car
2015 cherokee
2013 R/T classic
Re: 1942 dodge butterfly hood [Re: fstfish66] #483832
09/30/09 02:32 PM
09/30/09 02:32 PM
toledo ohio
P
P
toledo ohio
well, Lets assume that my car is a 1942, Of this I am not sure....It is titled as a 1941 but that it definately is not. If it is a 1942 then somebody butchered a pretty rare car...for all i know its a 1948. Either way I am not all for the butterfly hood or the homemade 90's grill, so something has got to change, just looking at options available currently. Those cars you posted are spot on with that 40 grill...I wish I had more background on the car.....You should see the interior....
Re: 1942 dodge butterfly hood [Re: pitbovver] #483833
09/30/09 02:40 PM
09/30/09 02:40 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
The 40-42 are different than the 46-48.
Look at the running board area.
Google search for the different years (even though some are labelled wrong) and you should be able to spot them.
That Canadian stuff sure adds another layer of complexity!
Re: 1942 dodge butterfly hood [Re: RodStRace] #483834
09/30/09 08:27 PM
09/30/09 08:27 PM
toledo ohio
P
P
toledo ohio
any guess to the year of this car? What would be some tell tale signs? dashboard?
Re: 1942 dodge butterfly hood [Re: pitbovver] #483835
10/01/09 01:22 AM
10/01/09 01:22 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
its deffinitly not a 48 a friend of mine we are currently working on a 48 your dash is more like a 41 ply,,then a 48 dodge,,so il assume your car is a 42....
2015 cherokee
2013 R/T classic
Re: 1942 dodge butterfly hood [Re: fstfish66] #483836
10/02/09 09:19 AM
10/02/09 09:19 AM
toledo ohio
P
P
toledo ohio
its hard to say what it is but i am leaning more and more towards a 42 is it possible the build date would be late 1941 but actually be a 1942 model thus the mix up in the title work....Is there a VIN registry i could apply the cars VIN against or is this even accurate? Heres another look....
Re: 1942 dodge butterfly hood [Re: pitbovver] #483837
10/02/09 10:29 AM
10/02/09 10:29 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Re: 1942 dodge butterfly hood [Re: RodStRace] #483838
10/02/09 12:36 PM
10/02/09 12:36 PM
toledo ohio
P
P
toledo ohio
Right on thanks for the information. It definately is a 1942 according to that information. I will have to verify the serial number on the door jamb to the one listed on the title....Thanks
Joe
Re: 1942 dodge butterfly hood [Re: pitbovver] #483839
10/02/09 01:15 PM
10/02/09 01:15 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
You are welcome, just remember to look through the older posts. Lots of stuff is here.
Re: 1942 dodge butterfly hood [Re: RodStRace] #483840
10/03/09 04:56 PM
10/03/09 04:56 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If you are looking for a 41Plymouth Nose let me know.I think my kid has one complete.I cant remember if both fenders are there bit hood grill etc is.Rocky
Chrysler Firepower
Re: 1942 dodge butterfly hood [Re: therocks] #483841
10/05/09 09:27 PM
10/05/09 09:27 PM
orangeville,PA
P
plmczy Offline
plmczy  Offline
P
orangeville,PA
Mopar hoods are a funny thing. plymouths are narrow at the cowl and 39 dodge hoods are shorter than a 40 hood. Lets just say I have 2 hoods I can't use. Oh yeah only 40 hoods rely on the hood moulding to complete the hinge, don't know if plymouths do but I know dodges are. Anybody have a good center chrome strip for a 40 dodge hood? later shawn
Re: 1942 dodge butterfly hood [Re: plmczy] #483842
10/06/09 12:38 AM
10/06/09 12:38 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
the center hinge cover seems to be a popular item along with trunk lids people are looking for,,my friends 48 dodge i think requires the molding to finish the hinge,,,il have to look at it again
2015 cherokee
2013 R/T classic
