Re: 1942 dodge butterfly hood
[Re: pitbovver]
#483824
09/29/09 11:53 PM
09/29/09 11:53 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
The whole front will need changed.I have a 41 Plymouth sitting The grill and fenders are definetly different.Yes the 41 opens from the firewall side.What is cheap for the hood?Rocky
Chrysler Firepower
[Re: therocks]
#483825
09/30/09 01:25 AM
09/30/09 01:25 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
in 1940 the canadian dodge used plymouth sheet metal all except the grille area,,,but that 42 looks kool
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: therocks]
#483826
09/30/09 12:44 PM
09/30/09 12:44 PM
Posts: 36 toledo ohio
pitbovver
toledo ohio
25 bucks for an unfinished one and 50 for a painted one....My grill and frontend have been modified by a P.O. with 1x1 aluminum square tube stock. I am not a big fan of the butterfly hood and am looking at different options in order to get into the engine compartment. Has anyone welded up and decked a butterfly hood? I was thinking the Plymouth would fit fairly nice with a little bit of fanagling. If it is narrower then I would think it would be easier to weld up the og hood instead of adding to a plymouth hood.....Any ideas?
[Re: fstfish66]
#483827
09/30/09 01:52 PM
09/30/09 01:52 PM
Posts: 1,884 Tracy CA
rabid scott
"You're Where?"
"You're Where?"
Tracy CA
Oh really? I need pictures!!
I have a 1940 Dodge Coupe that I'm looking for a hood for, maybe this will give me another option.
[Re: pitbovver]
#483828
09/30/09 01:56 PM
09/30/09 01:56 PM
fstfish66
levittown pa
wonder if the 41 plymouth front end would fit your 42 dodge?? or a 42 ply front end,,but that may be hard to locate,,
may be easier to shorten your hood from front to back and make it like a 40 dodge hood then weld it in to one piece,,and figure out hinges,, or make it open from one side or the other like a 50 buick does ,,weld it from undernieth or make a frame undernieth and keep the center hood trim making it look orignal from the out side,if the 41 ply front end would fit,that would be what i would do,unless you perfer the 42 dodge sheet metal,,it is more rare,yours is the first 42 dodge ive ever seen,,41 ply,s are sotra common. just mt .02 cents
[Re: rabid scott]
#483829
09/30/09 02:02 PM
09/30/09 02:02 PM
fstfish66
levittown pa
the american 40 dodge hood is only 3/4 as long front to back as the canadian,,,the canadian hood is full length from fire wall to almost the grille,,the canadian dodge uses plymouth sheet metal,,all except for the grille center mount,,, i am goig to try to post pics of both,,the blue car is american,,the copper is canadian,,,if not pics e mail me ill e mail them you fstfish66@aol.com
[Re: fstfish66]
#483830
09/30/09 02:06 PM
09/30/09 02:06 PM
fstfish66
levittown pa
pics i hope both hoods are butterfly
[Re: fstfish66]
#483832
09/30/09 02:32 PM
09/30/09 02:32 PM
pitbovver
toledo ohio
well, Lets assume that my car is a 1942, Of this I am not sure....It is titled as a 1941 but that it definately is not. If it is a 1942 then somebody butchered a pretty rare car...for all i know its a 1948. Either way I am not all for the butterfly hood or the homemade 90's grill, so something has got to change, just looking at options available currently. Those cars you posted are spot on with that 40 grill...I wish I had more background on the car.....You should see the interior....
[Re: pitbovver]
#483835
10/01/09 01:22 AM
10/01/09 01:22 AM
fstfish66
levittown pa
its deffinitly not a 48 a friend of mine we are currently working on a 48 your dash is more like a 41 ply,,then a 48 dodge,,so il assume your car is a 42....
[Re: RodStRace]
#483840
10/03/09 04:56 PM
10/03/09 04:56 PM
therocks
Niles , Ohio
If you are looking for a 41Plymouth Nose let me know.I think my kid has one complete.I cant remember if both fenders are there bit hood grill etc is.Rocky
Chrysler Firepower
[Re: plmczy]
#483842
10/06/09 12:38 AM
10/06/09 12:38 AM
fstfish66
levittown pa
the center hinge cover seems to be a popular item along with trunk lids people are looking for,,my friends 48 dodge i think requires the molding to finish the hinge,,,il have to look at it again
