WILL A 8 3/4 B-BODY REAREND FIT IN A A-BODY ??? #483755
09/29/09 08:42 PM
09/29/09 08:42 PM
South Dakota
Mirada440 Offline OP
South Dakota
Will the rear end out of a 62-70 b-body rearend fit into a plymouth scamp?? Ive been told by a few guy that it will work. Ive measured and they are pretty close but my main concern would be the pinion angle... Has anyone ever done this swap??
Re: WILL A 8 3/4 B-BODY REAREND FIT IN A A-BODY ??? [Re: Mirada440] #483756
09/29/09 08:47 PM
09/29/09 08:47 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
You can put one in, but you should move the spring perches as they are a bit too far apart. It will also cause the need to run wheels with lots of back spacing to clear the wheelwells. Stock wheels are a no-go unless your scamp is actually a Duster or Demon/Dart sport. If you are going to a more modern size wheel (17" & up), back spacing isn't really an issue since most are like that anyway. If all you want is the bolt pattern, you would be better off to get a later "undesireable" 8 1/4" A body axle.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: WILL A 8 3/4 B-BODY REAREND FIT IN A A-BODY ??? [Re: phantomx] #483757
09/29/09 09:03 PM
09/29/09 09:03 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Yes, thats what my dad has in his valiant, we just cut the perches off and moved them in and ajusted pinion angle...Works great..Got a set of 15x8 rimes with 5.5" bs....Phill
Re: WILL A 8 3/4 B-BODY REAREND FIT IN A A-BODY ??? [Re: phantomx] #483758
09/29/09 09:03 PM
09/29/09 09:03 PM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
The best one to use is from a 65-67 b body. They're a small bit narrower than the later ones.
Re: WILL A 8 3/4 B-BODY REAREND FIT IN A A-BODY ??? [Re: phantomx] #483759
09/29/09 09:03 PM
09/29/09 09:03 PM
NE Oklahoma
71valiant Offline
71valiant  Offline
NE Oklahoma
I put one in my valiant with no mods. Its an inch or less difference.
Re: WILL A 8 3/4 B-BODY REAREND FIT IN A A-BODY ??? [Re: 71valiant] #483760
09/30/09 12:22 AM
09/30/09 12:22 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I bolted in one from a 66 B in my 69 dart. No mods.
The spring pearch difference is mninimal, but as said, tire clearance does get a littel tight. I had a aset of ralleys offset inward at the time, and that worked.
As said- 65-67 are the best to go with. The diff dimensions in the archives are a little iffy
I think this one is more accurate
Re: WILL A 8 3/4 B-BODY REAREND FIT IN A A-BODY ??? [Re: dave571] #483761
09/30/09 02:36 AM
09/30/09 02:36 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
That's still wrong for most 8.75" a bodies.
Re: WILL A 8 3/4 B-BODY REAREND FIT IN A A-BODY ??? [Re: RobX4406] #483762
09/30/09 08:05 AM
09/30/09 08:05 AM
scratchnfotraction Offline
IMHO.just send the housing to Moser and have them cut it to A-body specs and weld the new perches on with 43" centers..shiping x 2 and about $65+ to narrow it
set of the $299 custom alloy axles with greens and large brake off set..
you can run any brakes from an 8 1/4, 8 3/4, 9 1/4,D-60...B,C,D,E,F,M,R body axles
unless you rather do the funky offset on rims
I did this for my 68 Dart and then swaped it into my 85 truck
still less $ in it than buying a 8 3/4 thats does not bolt and play and fit correctly
just a suggestion
Re: WILL A 8 3/4 B-BODY REAREND FIT IN A A-BODY ??? [Re: scratchnfotraction] #483763
09/30/09 08:24 AM
09/30/09 08:24 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
dr. diff sells a ready to bolt in A body housing, powdercoated, for something like $250. I assume he is narrowing a wider housing , they are empty you still need to buy a chuck, axles and brakes ...
Re: WILL A 8 3/4 B-BODY REAREND FIT IN A A-BODY ??? [Re: JohnRR] #483764
09/30/09 09:42 AM
09/30/09 09:42 AM
you can just buy a housing from moser also..$225
empty,dirty,no paint or powder coating..
good deal from the DOC,IMO..wish I knew that when I done mine in '01
Re: WILL A 8 3/4 B-BODY REAREND FIT IN A A-BODY ??? [Re: scratchnfotraction] #483765
09/30/09 01:08 PM
09/30/09 01:08 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
FWIW, Moser charges $445 for a custom axle package and $125 labor to narrow your housing.
Re: WILL A 8 3/4 B-BODY REAREND FIT IN A A-BODY ??? [Re: DoctorDiff] #483766
09/30/09 02:42 PM
09/30/09 02:42 PM
that price was from a 98 mag..my bad..little out dated ,I dont like giving prices either,bad habit
uhmm? got my A-body axles with greens for $299 and narrowed housing for $225 perches and labor to weld $50 + shiping
must have went up since 00'-01'
I need to give you a call anyways,I need another set of greens for the truck 8 3/4
Re: WILL A 8 3/4 B-BODY REAREND FIT IN A A-BODY ??? [Re: scratchnfotraction] #483767
09/30/09 03:21 PM
09/30/09 03:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
you thought that the price would not have changed in 8 years ??
Re: WILL A 8 3/4 B-BODY REAREND FIT IN A A-BODY ??? [Re: scratchnfotraction] #483768
09/30/09 03:22 PM
09/30/09 03:22 PM
My Moser axles were $427.00 delivered,well worth the money spent..
Re: WILL A 8 3/4 B-BODY REAREND FIT IN A A-BODY ??? #483769
09/30/09 03:32 PM
09/30/09 03:32 PM
I was looking at the mag when I posted and didnt relize it was out of date by that much..sorry
Re: WILL A 8 3/4 B-BODY REAREND FIT IN A A-BODY ??? [Re: Mirada440] #483770
09/30/09 05:16 PM
09/30/09 05:16 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
It depends on what wheels you plan on running for the most part, with 15's it probably wouldn't work too well and would be better off having one cut to A body size.
I've used them under duster/dart sports and A body Cudas since the 1/4 bulges more, I'm looking for a decent B body 8.75 to put under my Dart since I'm planning on going with 17" wheels. I have an A body width rear under it right now and the wheels I want to run need a 1.5" spacer to clear the leafs, the front is fine since the track is pushed out with 73+ discs.
