Re: WILL A 8 3/4 B-BODY REAREND FIT IN A A-BODY ???
[Re: Mirada440]
#483756
09/29/09 08:47 PM
09/29/09 08:47 PM
Posts: 982 W. Sacto CA. USA
phantomx
W. Sacto CA. USA
You can put one in, but you should move the spring perches as they are a bit too far apart. It will also cause the need to run wheels with lots of back spacing to clear the wheelwells. Stock wheels are a no-go unless your scamp is actually a Duster or Demon/Dart sport. If you are going to a more modern size wheel (17" & up), back spacing isn't really an issue since most are like that anyway. If all you want is the bolt pattern, you would be better off to get a later "undesireable" 8 1/4" A body axle. Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
[Re: dave571]
#483761
09/30/09 02:36 AM
09/30/09 02:36 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
I bolted in one from a 66 B in my 69 dart. No mods.
The spring pearch difference is mninimal, but as said, tire clearance does get a littel tight. I had a aset of ralleys offset inward at the time, and that worked.
As said- 65-67 are the best to go with. The diff dimensions in the archives are a little iffy
I think this one is more accurate
That's still wrong for most 8.75" a bodies.
[Re: RobX4406]
#483762
09/30/09 08:05 AM
09/30/09 08:05 AM
Posts: 15,487 Florida
scratchnfotraction
IMHO.just send the housing to Moser and have them cut it to A-body specs and weld the new perches on with 43" centers..shiping x 2 and about $65+ to narrow it set of the $299 custom alloy axles with greens and large brake off set.. you can run any brakes from an 8 1/4, 8 3/4, 9 1/4,D-60...B,C,D,E,F,M,R body axles unless you rather do the funky offset on rims ![](/ubbthreads/images/graemlins/shruggy.gif) I did this for my 68 Dart and then swaped it into my 85 truck ![](/ubbthreads/images/graemlins/boogie.gif) still less $ in it than buying a 8 3/4 thats does not bolt and play and fit correctly just a suggestion ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: JohnRR]
#483764
09/30/09 09:42 AM
09/30/09 09:42 AM
scratchnfotraction
you can just buy a housing from moser also..$225 empty,dirty,no paint or powder coating.. good deal from the DOC,IMO..wish I knew that when I done mine in '01 ![](/ubbthreads/images/graemlins/beer.gif)
[Re: DoctorDiff]
#483766
09/30/09 02:42 PM
09/30/09 02:42 PM
scratchnfotraction
that price was from a 98 mag..my bad..little out dated ![](/ubbthreads/images/graemlins/whistling.gif) ,I dont like giving prices either,bad habit ![](/ubbthreads/images/graemlins/2516024-blahblah.gif) uhmm? got my A-body axles with greens for $299 and narrowed housing for $225 perches and labor to weld $50 + shiping must have went up since 00'-01' I need to give you a call anyways,I need another set of greens for the truck 8 3/4 ![](/ubbthreads/images/graemlins/wave.gif)
[Re: scratchnfotraction]
#483767
09/30/09 03:21 PM
09/30/09 03:21 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
that price was from a 98 mag..my bad..little out dated ,I dont like giving prices either,bad habit ![](/ubbthreads/images/graemlins/2516024-blahblah.gif)
you thought that the price would not have changed in 8 years ?? ![](/ubbthreads/images/graemlins/laugh2.gif)
