Re: Wilwood brake question
[Re: WILD BILL]
#483738
09/29/09 08:49 PM
09/29/09 08:49 PM
I Have a TF's in all my cars and have 4 wheel wilwood brakes and mine roll very easy. jack up the rear end and disconnect the driveshaft and turn yourrear wheels and see if its your rear, brakes or tranny, its process of elimination. it wont take you longer than 15 minutes total to isolate your problem.
[Re: mopar dave]
#483741
09/30/09 09:36 AM
09/30/09 09:36 AM
Posts: 644 Minnesota
Barnstorm
Minnesota
Heres the cure that worked for us. Replace the square caliper seals with round ones and put a 2" compression spring along the cotter pin to keep the pads retracted. Picked up 2mph.
The little old lady from Pasadena is back!
[Re: Otherlane]
#483744
09/30/09 02:36 PM
09/30/09 02:36 PM
Barnstorm
Minnesota
My rear setup is Stange discs, also hard to push[spool, 4.89]. Never a drag problem there. U can usually check rear drag by lifting the rear off the ground and rotating the tires back and forth[mine has about 1 1/2" of slack] against the ring gear..if rears are dragging, no slack.
