Wilwood brake question #483733
09/29/09 07:56 PM
09/29/09 07:56 PM
east coast
Otherlane Offline OP
east coast
I have wilwood rear disc brakes on my car and i not it was really hard to pushing the car.The question i have if i look inside the caliber i can see the piston in the outer but not on the inner.should i be able to see both evenly? if so what can i do to fix the problem?
Re: Wilwood brake question [Re: Otherlane] #483734
09/29/09 08:01 PM
09/29/09 08:01 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Is it a TF tranny? If so it's not the brakes. TF's are always hard to push.
Re: Wilwood brake question [Re: Otherlane] #483735
09/29/09 08:02 PM
09/29/09 08:02 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Is the caliper spaced correctly over the rotor. Sometimes they need shimed a little.
Re: Wilwood brake question [Re: WILD BILL] #483736
09/29/09 08:29 PM
09/29/09 08:29 PM
east coast
east coast
Yes its a t/f car.so t/f cars are hard to push,why is that? I did shim the hat off the housing but when I did that I can move the axle in and out about 1/8 of a inch.where should I shim the hat or caliber?
Re: Wilwood brake question [Re: Otherlane] #483737
09/29/09 08:38 PM
09/29/09 08:38 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
By hat do you mean the braket that the caliper bolts to?
If so that should not be shimmed and is used to retain the bearing in the housing.
The shims (if needed) would go between that and the caliper itself.
Re: Wilwood brake question [Re: WILD BILL] #483738
09/29/09 08:49 PM
09/29/09 08:49 PM
I Have a TF's in all my cars and have 4 wheel wilwood brakes and mine roll very easy.
jack up the rear end and disconnect the driveshaft and turn yourrear wheels and see if its your rear, brakes or tranny, its process of elimination. it wont take you longer than 15 minutes total to isolate your problem.
Re: Wilwood brake question #483739
09/29/09 09:19 PM
09/29/09 09:19 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i noticed my wilwood fronts were easy to turn when first installed and street driven but, now after 14 passes down the track they are hard to turn, like there draging.
Re: Wilwood brake question [Re: mopar dave] #483740
09/30/09 12:30 AM
09/30/09 12:30 AM
east coast
east coast
Yes Wild bill that is what i am talking about.That bracket should lay flat on the housing as you said i dont shims will help me out.i will have to double check tomorrow.Superstockracer i am planning on doing what you said to see if its the brakes.mopar dave,i have heard that the wilwood brakes do drag a little bit so i think that is normal but we dont want that as it slow down the car
Re: Wilwood brake question [Re: mopar dave] #483741
09/30/09 09:36 AM
09/30/09 09:36 AM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Heres the cure that worked for us. Replace the square caliper seals with round ones and put a 2" compression spring along the cotter pin to keep the pads retracted. Picked up 2mph.
The little old lady from Pasadena is back!
Re: Wilwood brake question [Re: Otherlane] #483742
09/30/09 09:43 AM
09/30/09 09:43 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
On my Wilwood rears I had to file one side of the caliper bracket to center the caliper over the rotor. Mine is a lot harder to push with slicks on than with the radials.
Re: Wilwood brake question [Re: justinp61] #483743
09/30/09 12:31 PM
09/30/09 12:31 PM
east coast
east coast
Barnstorm,thanks for the info I will have to do that.2 mph is alot.justin Im thinking I will have to do what you did to center my caliber.
Re: Wilwood brake question [Re: Otherlane] #483744
09/30/09 02:36 PM
09/30/09 02:36 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
My rear setup is Stange discs, also hard to push[spool, 4.89]. Never a drag problem there. U can usually check rear drag by lifting the rear off the ground and rotating the tires back and forth[mine has about 1 1/2" of slack] against the ring gear..if rears are dragging, no slack.
Re: Wilwood brake question [Re: Barnstorm] #483745
09/30/09 02:56 PM
09/30/09 02:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Did that increase the pedal travel?
Re: Wilwood brake question [Re: John_Kunkel] #483746
09/30/09 03:09 PM
09/30/09 03:09 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
No difference.
