Tubular A Arms? #483116
09/28/09 11:47 PM
09/28/09 11:47 PM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
How much more caster can you get with Tubular A Arms?
Which ones are worth looking into?
AL....
Alan Jones
Re: Tubular A Arms? [Re: LA360] #483117
09/29/09 09:07 AM
09/29/09 09:07 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I have RMS uppers with heim joints. I can get over 8º positive caster
with them. (3º-3.5º recommended for drag racing)
My brother bought the CAPs with urethane bushings. They told him there
was already 1º or 2º positive over OEM, as shipped. (adjustable as well)
Old Post
Check with Bondobob on his.
Re: Tubular A Arms? [Re: S/ST 3040] #483118
09/29/09 07:08 PM
09/29/09 07:08 PM
LA360 Offline OP
LA360  Offline OP
I need the small ball joint which will remove a few from the list. Anyone else?
AL....
Alan Jones
Re: Tubular A Arms? [Re: LA360] #483119
09/29/09 07:21 PM
09/29/09 07:21 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
BobsProFab.com
Re: Tubular A Arms? [Re: moparguy7074] #483120
09/29/09 07:52 PM
09/29/09 07:52 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
BobsProFab.com
2nd that
Re: Tubular A Arms? [Re: LA360] #483121
09/29/09 08:09 PM
09/29/09 08:09 PM
toronto ontario
badwej Offline
badwej  Offline
toronto ontario
AL....
drill the spindal
badwej@hotmail.com Sean Parker Toronto Ontario Canada
Re: Tubular A Arms? [Re: badwej] #483122
09/29/09 08:11 PM
09/29/09 08:11 PM
LA360 Offline OP
LA360  Offline OP
AL....
drill the spindal
The large ball joint would be an import, I can go down to any parts store and pic up one of the small ball joints.
AL....
Alan Jones
Re: Tubular A Arms? [Re: LA360] #483123
09/29/09 08:11 PM
09/29/09 08:11 PM
Rudolph, Ohio
Rudolph, Ohio
here is a pic.
Re: Tubular A Arms? [Re: moparguy7074] #483124
09/29/09 09:24 PM
09/29/09 09:24 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
you can use the large or small ball joint with the CAP arms. i just coverted over to the large joints on the CAP arms, way better geometry and strength.
Re: Tubular A Arms? [Re: LA360] #483125
09/30/09 01:13 AM
09/30/09 01:13 AM
Sacramento,California
JRepucci Online content
JRepucci  Online Content
How much weight do you think you save by going to willwood discs, and tubular upper and lower control arms over stock pieces and drum brakes on an A-body?
