Page 2 of 7 1 2 3 4 5 6 7
Re: W9 Header flanges 3/8" or 1/2"??? [Re: Plumb Wired] #48303
11/29/07 01:18 AM
11/29/07 01:18 AM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
I got my W8 flanges from SPD, www.spdexhaust.com
Available for most all SB Mopar heads in mild steel or stainless, 3/8" or 1/2" thick. Very nice pieces!
Mike Gray
They might be nice but at those prices
Racer $81 for one side ($22 a piece for a left and right port $37 for the center ports)
Dealer $69.66 ($18.92 a side $31.82 center)
Jobber $56.70 ($15.40 a side $25.90 center)
These will be just as nice at almost half the price.
Do you guys want three piece? We can change the CNC program to trim them out.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: W9 Header flanges 3/8" or 1/2"??? [Re: Plumb Wired] #48304
11/29/07 10:10 AM
11/29/07 10:10 AM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
Mike Gray
Mike which ones did you order , they list 2 different ones for the W8 head, i need the stainless ones.
Bondo
Re: W9 Header flanges 3/8" or 1/2"??? [Re: BobsProFab] #48305
11/29/07 10:34 AM
11/29/07 10:34 AM
PA
moparacer Offline
moparacer  Offline
PA
There are 2 W8 flanges. Kaliher showed them to me when he made my dragster headers.
Better make sure what you have before you order....
Re: W9 Header flanges 3/8" or 1/2"??? [Re: moparacer] #48306
11/29/07 10:57 AM
11/29/07 10:57 AM
pa
catman408 Offline
catman408  Offline
pa
i need to know which one i need? the part # is P4532933 ON THE HEADS I OWN
1989 lebaron 408 B1BA 5.969 1/8@ 116.16 9.393 1/4 @ 148.83 New motor 426 w8 5.683 @122.49 1/8 8.88 @153.49 1/4
Re: W9 Header flanges 3/8" or 1/2"??? [Re: catman408] #48307
11/29/07 11:02 AM
11/29/07 11:02 AM
Menomonee Falls
Menomonee Falls
Any other numbers on the heads? I'm pretty sure they are W9's. Maybe Ryan will see the post and know.
SDG Motorsports
Re: W9 Header flanges 3/8" or 1/2"??? [Re: catman408] #48308
11/29/07 11:44 AM
11/29/07 11:44 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
If it is a W9 it uses a standard W8 circle track bolt pattern. Only the Drag W8 has a larger bolt pattern... & then W9RP is it's own seperate entity.
Re: W9 Header flanges 3/8" or 1/2"??? [Re: DemonDust] #48309
11/29/07 11:45 AM
11/29/07 11:45 AM
pa
catman408 Offline
catman408  Offline
pa
IT HAS W8 RIGHT ABOVE THE NUMBER
Re: W9 Header flanges 3/8" or 1/2"??? [Re: catman408] #48310
11/29/07 11:54 AM
11/29/07 11:54 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
On a W8, on one of the outer cylinders the bolt spacing will be 3.06" CL to CL if it is a circle track casting, which shares same bolt pattern with all "normal" W9's. If it is wider than that, it is a Drag head.....
Re: W9 Header flanges 3/8" or 1/2"??? [Re: RyanJ] #48311
11/29/07 12:13 PM
11/29/07 12:13 PM
pa
catman408 Offline
catman408  Offline
pa
ITS 3.06" CL to CL YOU THE MAN
Re: W9 Header flanges 3/8" or 1/2"??? [Re: catman408] #48312
11/29/07 12:17 PM
11/29/07 12:17 PM
Menomonee Falls
Menomonee Falls
So I should mark you down for a set of W9's then
SDG Motorsports
Re: W9 Header flanges 3/8" or 1/2"??? [Re: DemonDust] #48313
11/29/07 04:58 PM
11/29/07 04:58 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Bob,
The truck series heads use the small pattern 4.750" as measured between the bolt centers on the center ports, the NHRA Pro Stock or Drag Race as SPD refers to it uses the larger pattern 4.875".
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: W9 Header flanges 3/8" or 1/2"??? [Re: Plumb Wired] #48314
11/29/07 10:06 PM
11/29/07 10:06 PM
pa
catman408 Offline
catman408  Offline
pa
YES YES YES
Re: W9 Header flanges 3/8" or 1/2"??? [Re: Plumb Wired] #48315
11/29/07 10:22 PM
11/29/07 10:22 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
Bob,
Mike Gray
THANKS
Re: W9 Header flanges 3/8" or 1/2"??? [Re: BobsProFab] #48316
11/29/07 10:29 PM
11/29/07 10:29 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
I'll take them one piece as long as they have thin strips in between.
Re: W9 Header flanges 3/8" or 1/2"??? [Re: DemonDust] #48317
12/03/07 09:33 AM
12/03/07 09:33 AM
Menomonee Falls
Menomonee Falls
SDG Motorsports
Re: W9 Header flanges 3/8" or 1/2"??? [Re: DemonDust] #48318
12/23/07 01:40 AM
12/23/07 01:40 AM
Menomonee Falls
Menomonee Falls
Ok guys I got the time off. We'll prolly get around to burning the parts next week. I can do 1/2" and 3/8".
Guys on the list for 1/2":
Dizuster
Catman 408
Dos Snails
No one for 3/8"
Besides how many people tell me they want them. I will only make a 2-3 sets more a piece. So if you are not on the list and want some please PM me your shipping address and what type you want. I will then send you a PM with my address to Ship the MO or cashiers check to. If you guys insist on paying by paypal 3% will be added to the total.
SDG Motorsports
Re: W9 Header flanges 3/8" or 1/2"??? [Re: DemonDust] #48319
12/23/07 02:07 AM
12/23/07 02:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Dizuster
Catman 408
Dos Snails
No one for 3/8"
Can you burn a couple of sets out of 304 stainless
for the standard W-9 if so I'll take 2 sets in
either 1/2 or 3/8, I prefer 3/8
Re: W9 Header flanges 3/8" or 1/2"??? [Re: MR_P_BODY] #48320
12/23/07 02:17 AM
12/23/07 02:17 AM
Menomonee Falls
Menomonee Falls
If we have some drop laying around we could do it. I'll have to see.
SDG Motorsports
Re: W9 Header flanges 3/8" or 1/2"??? [Re: DemonDust] #48321
12/23/07 08:17 AM
12/23/07 08:17 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I'm in for a set w9 3/8" SS, if possible also, PM terms address, etc Thanks
Re: W9 Header flanges 3/8" or 1/2"??? [Re: jcc] #48322
12/23/07 09:36 AM
12/23/07 09:36 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
My W8 CFE heads have a bolt flange of 4.975" between centres of the centre exhaust ports
AL...
Alan Jones
