What clutch and shifter for street?? #483056
09/28/09 10:17 PM
09/28/09 10:17 PM
Ontario, Canada
Hyper Henry Offline OP
Ontario, Canada
Hey Guys
Doing a 4-speed conversion on my 68 Barracuda street car and wondering what you recommend for good clutch disc/pressure plate and shifter combo I plan on running it with a pistal grip as well
Derrick
Re: What clutch and shifter for street?? [Re: Hyper Henry] #483057
09/28/09 10:42 PM
09/28/09 10:42 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
If it's just a street machine with occasional strip action a basic clutch kit from any auto parts store will hold up for years. Hurst shifter is probably the best choice for the pistol grip shifter, all the competition plus body's are the same , just a different mounting plate to the transmission.
Re: What clutch and shifter for street?? [Re: Hyper Henry] #483058
09/28/09 11:54 PM
09/28/09 11:54 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
mcleod street twin here.light pedal and you cant hurt it.....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: What clutch and shifter for street?? [Re: Hyper Henry] #483059
09/29/09 06:51 PM
09/29/09 06:51 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Hey Guys
Derrick
What engine,trans,bell,flywheel size? If you have a 143 tooth bell/wheel combo then I suggest the 12"Mcleod B&B plate and rag disc from Passon Performance.If you only have a 130 tooth bell/wheel then you are more limited in your choices.I like the Hurst Super Shifter III for a street/strip unit,I have run over 40 passes without missing a gear with that shifter.
Gus
64 Plymouth Savoy
Dana 60
Re: What clutch and shifter for street?? [Re: Old School] #483060
09/30/09 12:21 PM
09/30/09 12:21 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
We have several choices on clutches/shifters, in stock and ready to ship, give us a call!!
Wayne/Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
