Beehive springs on a street hemi??
#483022
09/28/09 09:02 PM
09/28/09 09:02 PM
Posts: 2,521 Richmond Va, KeislerTKO 60...
VanishPt
anyone using Beehives on a 426 style hemi? Seems like a lot of motors are using them now. I know the argument might be that a lot of motors do not have the valves facing each other . I just wonder how much dual springs would help in that instant when a spring broke.?? Seems like alot of damage would occur with either setup? This would be for about a 650 net lift solid roller. Thanks
Re: Beehive springs on a street hemi??
[Re: VanishPt]
#483023
09/28/09 09:12 PM
09/28/09 09:12 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
IMO I wouldnt go with Bee Hive springs in any kind of a performance Hemi build knowing they "All" like to RPM pretty high...
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: VanishPt]
#483024
09/28/09 09:56 PM
09/28/09 09:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Maybe they've come up with some beehives that have more spring pressure but I havent seen any that can take a roller along with big valves
[Re: VanishPt]
#483025
09/29/09 12:16 AM
09/29/09 12:16 AM
Posts: 43,193 Bend,OR USA
Cab_Burge
Why would you want to run a spring that wasn't design for a 426 Hemi head Especially on a roller cam, beehives are a compromised design for the heads that cannot run a 1.550 or bigger diameter valve spring Buy the best springs you can, not a set of beehives, no matter what the prices are
Post deleted by Defbob
[Re: AndyF]
#483030
09/29/09 11:35 AM
09/29/09 11:35 AM
#483031
09/29/09 03:49 PM
09/29/09 03:49 PM
VanishPt
actually i did email with Tim, and that is where the idea originated. my motor has 4.5 crank in it. I probably would not go past 65-6700 rpm. A single spring just does not seem right on a Hemi
[Re: VanishPt]
#483032
09/29/09 05:27 PM
09/29/09 05:27 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
No beehives on a performance engine.They will break at some point, it's not will they, it's when!
Leave the gun.......take the Cannoli's....Mike
[Re: VanishPt]
#483034
09/30/09 07:20 PM
09/30/09 07:20 PM
Posts: 31,041 Oregon
AndyF
If Tim has a part number of a spring that will work with your cam then I'd trust him. He is a sharp engine builder. There is a place in MI that builds a lot of the valve springs used by the cam companies. I forget the name at the moment but they have a big selection of beehives. My guess is that Tim is hooked up with them directly. Google is my friend: PAC http://www.racingsprings.com/beehivesprings.asp
