Post deleted by Defbob
[Re: Forest]
#482032
09/27/09 11:06 PM
09/27/09 11:06 PM
Re: 426 hemi block 2468330-M
[Re: Cab_Burge]
#482035
09/28/09 09:03 AM
09/28/09 09:03 AM
Posts: 916 SE Washington
Forest
SE Washington
Unless it was a unbored siamse block(not likely probally) it won't take much more than a stock street hemi block will on the bore size, 4320 max usualy I built one of those blocks that was 4,180 unbored, I had it sonic tested and decided to bore it to 4.25 and leave at that. I used a 4.375 stroke blower crankshaft with counterweights to use with the 10:71 Littlefield blower, Stage V heads and two 1050 blower Domintor carbs. that combination made 925 HP at 7300 RPM with 7 lbs of boost on CA pump gas several years back
That combo sounds pretty close to how I see this project turning out, thanks for your input.
[Re: Cab_Burge]
#482037
09/28/09 12:40 PM
09/28/09 12:40 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
I will trade my new World Hemi block for a new older Mopar Performance Hemi block.
It sounds like the block you have is a Mopar Performance replacement block. They are a good block up to .060 and should be sonic checked after that. They look more like a stock block than the World block, that is why I'm looking for one.
PM me if your interested.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
