American Muscle Car Revolution Resto Job as Promised.
#481174
09/27/09 03:17 PM
09/27/09 03:17 PM
Posts: 1,054 Roswell, GA - near Atlanta
cloneguy
super street
super street
OK guys. Here we have a very, very nice original U code Track Pack 1970 Cuda. It's an LA car with no rust anywhere due to some super heavy undercoating that was applied by the original owner. We love it and we hate it.
It saved all of the metal but it took a lot of work to get it off of the car for the restoration.
Per the owner's request, this car is being stripped to bare metal (which we always do by hand) and restored with factory style primer/overspray on the bottom. All suspension detailing will be done per factory specs and all OEM inspection markings, etc.
If not for the undercoating removal, this job would have come in at about 65% of our max labor cap.
The car was either in a hail storm or was parked under an oak tree as it sustained 51 small dents on the top side. Additionally, it had been tapped in the left quarter, from the rear and filled.
Re: American Muscle Car Revolution Resto Job as Promised.
[Re: cloneguy]
#481176
09/27/09 03:20 PM
09/27/09 03:20 PM
cloneguy
super street
super street
Anyway, since this is a 100% original metal car, we strive to use as little filler as possible. So we heat shrink, quench and file each dent until none is necessary whenever possible.
[Re: cloneguy]
#481180
09/27/09 03:25 PM
09/27/09 03:25 PM
340dart4spd
Parts Problem
Parts Problem
Step 3
what no pic's
[Re: cloneguy]
#481182
09/27/09 03:38 PM
09/27/09 03:38 PM
cloneguy
super street
super street
OK, here is Hubert having great fun with the undercoating removal. First we hit it with a chemical stripping agent to be sure that we didn't damage any metal. As you can see, it leaves behind a film that we then remove with a needle scaler.
Let me add here that by the time Hubert finished removing all of the undercoating, we were able to fill a whole trash can with the debris!
[Re: cloneguy]
#481183
09/27/09 03:39 PM
09/27/09 03:39 PM
cloneguy
super street
super street
After using the needle scaler in about 12 inch by 12 inch squares, Hubert hits the bottom with primer/sealer.
[Re: cloneguy]
#481184
09/27/09 03:43 PM
09/27/09 03:43 PM
cloneguy
super street
super street
Here is the dent that was filled on the rear of the car. We were able to shrink this one back to the point that it needed less than 1/16" of filler. Unfortunately it wouldn't cooperate 100%. This is the before photo.
[Re: cloneguy]
#481185
09/27/09 03:53 PM
09/27/09 03:53 PM
cloneguy
super street
super street
At the point of these photos, we are 4 weeks into the restoration.
We've disassembled the car, put it on the rotisserie, stripped all paint and undercoating, removed all dents using the heat shrink method. Done all body work and are ready to primer/seal and block.
By week 6, the car will be painted. 75% of the work so far has been done by Hubert with help from Mike.
For those ladies out there who might be interested, Hubert is 70 years old and single. He has more energy than the other two of us put together, so be ready to rock!
[Re: 340dart4spd ]
#481187
09/27/09 04:14 PM
09/27/09 04:14 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
I can see all the pics...
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: EWJ]
#481188
09/27/09 04:23 PM
09/27/09 04:23 PM
340dart4spd
Parts Problem
Parts Problem
[Re: cloneguy]
#481189
09/27/09 04:27 PM
09/27/09 04:27 PM
340dart4spd
Parts Problem
Parts Problem
why not etching primer??
[Re: 340dart4spd ]
#481190
09/27/09 04:30 PM
09/27/09 04:30 PM
cloneguy
super street
super street
It is. I'm just the mechanic.
[Re: cloneguy]
#481191
09/27/09 05:07 PM
09/27/09 05:07 PM
Posts: 27,467 So Cal
autoxcuda
So Cal
... All suspension detailing will be done per factory specs and all OEM inspection markings, etc..
Do you have pics of the factory underside inspection marks you found that were left on this very clean original car??
[Re: autoxcuda]
#481192
09/27/09 05:19 PM
09/27/09 05:19 PM
cloneguy
super street
super street
Um, I don't think I said that it was very clean but I'm pretty sure I did say that it was covered with extremely thick undercoating.
[Re: cloneguy]
#481193
09/27/09 05:48 PM
09/27/09 05:48 PM
autoxcuda
So Cal
Sorry, in underside I meant front and rear suspension, rear springs, center section...
