throttle pressure adjustment or kick down linkage #481126
09/27/09 01:32 PM
09/27/09 01:32 PM
btomasko Offline OP
btomasko  Offline OP
what would be a good way to adjust the throttle pressure linkage or kick down linkage please explain in laymens terms roadrunner 440 727 another words how would you attempt to do this thanks. does not shift into high at wot.
Re: throttle pressure adjustment or kick down linkage [Re: btomasko] #481127
09/27/09 01:41 PM
09/27/09 01:41 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
1 peice kick down or 3 peice?
Re: throttle pressure adjustment or kick down linkage [Re: Dougsmopars] #481128
09/27/09 05:32 PM
09/27/09 05:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
When you say won't shift how many rpms did you get up to in 2nd?
Re: throttle pressure adjustment or kick down linkage [Re: stumpy] #481129
09/27/09 05:40 PM
09/27/09 05:40 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The piece of linkage for the kickdown that attaches to the carb throttle lever. Pop that piece off the lever and turn it clockwise(if you're looking at it from the front of the car).
This will shorten the rod.
The way you should have it setup is at idle the kickdown linkage is pulled fully forward. But as soon as you start to press the throttle it starts to move the kickdown. At WOT there may still be some slack left, ie at full throttle the kickdown still may be able to go a little more to the back, this is okay. Give that a try and see if it helps.
Re: throttle pressure adjustment or kick down linkage [Re: DaytonaTurbo] #481130
09/27/09 06:26 PM
09/27/09 06:26 PM
btomasko Offline OP
btomasko  Offline OP
one piece, the rpms were quite high 3500 or better
Re: throttle pressure adjustment or kick down linkage [Re: btomasko] #481131
09/27/09 10:26 PM
09/27/09 10:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Wide open throttle will go to 4800 or better before shifting. Did it shift if you let up a little? 3500 rpm isn't very high.
Re: throttle pressure adjustment or kick down linkage [Re: stumpy] #481132
09/28/09 07:13 AM
09/28/09 07:13 AM
btomasko Offline OP
btomasko  Offline OP
yes it did
Re: throttle pressure adjustment or kick down linkage [Re: btomasko] #481133
09/28/09 10:00 AM
09/28/09 10:00 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
yes it did
what RPM does it shift at 1-2 and 2-3 at WOT ???
Re: throttle pressure adjustment or kick down linkage [Re: JohnRR] #481134
09/28/09 12:21 PM
09/28/09 12:21 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I don't think you have any problem. It sounds like it's working like it should.
Re: throttle pressure adjustment or kick down linkage [Re: stumpy] #481135
09/28/09 04:35 PM
09/28/09 04:35 PM
Dougsmopars Offline
Dougsmopars  Offline
3500 is not high for up shift at WOT. Sounds a bit low to me. At WOT mine shifts into 3rd at 4600.
