440 weight #481060
09/27/09 11:46 AM
09/27/09 11:46 AM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Anyone know what the weight of a early (66-67) 440 block weighs compared to a late (75) 440? I weight my car this weekend. Last time it weighted 3040 w/out me. Since then I changed to alum heads, alum water pump, stock pan to a 8 qt pan. Also went from a 66 to a 75 block but internals of the motors are the same. Now the car weights 3055 w/out me? Thinking the block has to be alot heavier, and was wondering what the acutal weight difference is. thanks.
Re: 440 weight [Re: DusterKid] #481061
09/27/09 06:46 PM
09/27/09 06:46 PM
I don't think any of the passenger car blocks where much(5 to 10 lbs heavier ) heavier than the rest of the years. Mopar did make the 440-3 motor home blocks that had extra reinforcing ribs on the sides and extra cooling passages in the block and heads to cool the exhaust valves but I don't remember them being noticably heaveir than the passenger car blocks when moving them around and loading them into and out of the truck to go to the machine shops
Re: 440 weight [Re: DusterKid] #481062
09/27/09 08:40 PM
09/27/09 08:40 PM
AndyF Offline
AndyF  Offline
I've weighed lots of blocks and never seen any pattern by the year. The heaviest block I ever weighed (also had the thickest cylinder walls) was a 1978 440 motor from a passenger car. So much for the "thin wall" theory!
