I think I broke it... #480841
09/27/09 12:49 AM
09/27/09 12:49 AM
Yes
sixpakdodge Offline OP
Yes
The #2, 3, and 4 mains all look like this. The cylinder walls in 1, 6, and 7 are cracked on one side each, 3 and 5 are cracked on both sides, and #8 is cracked too. It was bound to happen though. the block served me well. At least 750+ passes down the 1/4 between two different cars.
Combo was always the same. 440 +.060, Steel crank, Six Pack rods, flat tops, Comp .650 solid, 452 heads, M-1 intake, and a 1050 Dominator. It went 9.73 @ 138 at the beginning of the year in my Plymouth.
Re: I think I broke it... [Re: sixpakdodge] #480842
09/27/09 06:48 AM
09/27/09 06:48 AM
Colorado
506RR Offline
506RR  Offline
Colorado
I think you got your money's worth!
Re: I think I broke it... [Re: sixpakdodge] #480843
09/27/09 07:12 AM
09/27/09 07:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep you broke it... time to find out the scrap rate
for cast iron
Re: I think I broke it... [Re: MR_P_BODY] #480844
09/27/09 08:36 AM
09/27/09 08:36 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Call Chrysler and ask the what kind of crap they are passing off to the public, can't even get 1,000 pass's [ 250 ] miles out of their blocks. Putting the juice to it ?
Re: I think I broke it... [Re: rowin4] #480845
09/27/09 08:54 AM
09/27/09 08:54 AM
, PA
sleepyhead416 Offline
, PA
BRUTUS That brings back memories,
Re: I think I broke it... [Re: rowin4] #480846
09/27/09 08:56 AM
09/27/09 08:56 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
It needed a girdle and it would have lived. 6pac rods? You did so much wrong initially and that's why it didnt go 800 runs...
(jk)
Re: I think I broke it... [Re: sixpakdodge] #480847
09/27/09 09:08 AM
09/27/09 09:08 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
YUP ! Sure looks broke to me !
Best of luck on the new build !
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: I think I broke it... [Re: rowin4] #480848
09/27/09 11:05 AM
09/27/09 11:05 AM
Yes
Yes
All throttle, I have never and will never juice anything.
It could have a 1,000 runs on it actually. The motor was in the '64 Dodge when we got in in 1995. God only knows how many runs the prior owner made on the motor.
The new motor will have a girdle, alum. rods, pistons, etc. I'm actually thinking of a Mega Block.
Re: I think I broke it... [Re: sixpakdodge] #480849
09/27/09 07:54 PM
09/27/09 07:54 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Been there, done that (more than once)
I say you got your moneys worth!!!!
