where do u shift your big block?? #480717
09/26/09 11:48 PM
09/26/09 11:48 PM
Illinois
moparmattkos Offline OP
mopar addict
mopar addict
Illinois
I have a 451 stroker what kinda rpms do these like the most with a solid flat tappet cam? I am shifting at 6200 now and a few people say the 451 pulls the best it like 7200 any thoughts on this?
www.sikosracing.net Heads up Drag racing
Re: where do u shift your big block?? [Re: moparmattkos] #480718
09/27/09 12:16 AM
09/27/09 12:16 AM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
6800 here
Re: where do u shift your big block?? [Re: 540dust] #480719
09/27/09 12:19 AM
09/27/09 12:19 AM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
depends on set up, back in the ezstreet days i ran lots spring pressure and about 700 lift, shifted at 7600 on lots of nos (cross bar with two 85 nos and two 82 fuel).
Re: where do u shift your big block?? [Re: rtstreet] #480720
09/27/09 12:41 AM
09/27/09 12:41 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
8200:p Well that is where we shift the Cuda but it is a 525"er
FWIW my ole 451 in the Belvedere worked best at 6700. Steel rod SR head ran mid 10's at 3770lbs with a Scott Brown cam.
Re: where do u shift your big block?? [Re: moparmattkos] #480721
09/27/09 12:45 AM
09/27/09 12:45 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
10,500? You really don't offer enough info to possibly help you,what do you want? A lucky guess?
Re: where do u shift your big block?? [Re: goldmember] #480722
09/27/09 12:51 AM
09/27/09 12:51 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
My 452 liked 6600.
Re: where do u shift your big block?? [Re: sixpakdodge] #480723
09/27/09 01:27 AM
09/27/09 01:27 AM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
6800 here too
Re: where do u shift your big block?? [Re: moparmattkos] #480724
09/27/09 01:54 AM
09/27/09 01:54 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Either you got a real small cam, or you're sandbagging......
Re: where do u shift your big block?? [Re: moparmattkos] #480725
09/27/09 09:03 AM
09/27/09 09:03 AM
NC
440Jim Offline
440Jim  Offline
NC
The key part of that is solid flat tappet cam. Although with extreme setups it can rpm sky high, most valvetrain setups will need attention over 7000 rpm. And between 6500 and 7000 valve spring surge can be an issue unless you take some steps to avoid it. With a few tricks you can go 7500, but the spring pressures risk wearing/wiping a lobe, unless you use ceramic faced lifters (Schubeck style)
Ofcourse, your head flow, cam duration, etc. all play a role on what to shift your engine at.
Re: where do u shift your big block?? [Re: 440Jim] #480726
09/27/09 09:41 AM
09/27/09 09:41 AM
gregsdart Offline
gregsdart  Offline
More engine/trans info needed to help figure out a starting shift point for your specific combo.
Re: where do u shift your big block?? [Re: moparmattkos] #480727
09/27/09 10:36 AM
09/27/09 10:36 AM
IN
Dartman928 Offline
Dartman928  Offline
IN
5800rpm runs 9.7's
Re: where do u shift your big block?? [Re: Dartman928] #480728
09/27/09 10:52 AM
09/27/09 10:52 AM
Ohio
Lil Wedge Offline
Lil Wedge  Offline
Ohio
A guy we was pitted with at Norwalk had 500 cid in a Demon and he had bought the engine already together out of a dragster, Indy heads and intake , roller cam, dominator carb, He was told by original owner shift at 7500, He was conservative and was shifting at 6800 and was running 9.95. wanted to slow down for 10.0 shootout so backed it down to 6000 and car went 9.90, backed it down to 5500 and car went 9.84. Decided if He was going to slow down this way, He was going to have to shift at 7000,lol
Re: where do u shift your big block?? [Re: moparmattkos] #480729
09/27/09 12:52 PM
09/27/09 12:52 PM
I have ran a lot of different BB combinations, the 451 is a 440 stock stroke crankshaft in a low deck, it is the same as a 440 with .060 overbore. I ran one of those with a set of M.W. heads, intake and 750 carbs, we could slow that car down a tenth by moving the shift points in 1st and 2nd gear from 6400 RP to 7000 RPM. That was with a Isky 616-590 grind with all Isky valve train parts with the springs set up the way they wanted them My point is you will have to take the car out and try different shift points to find out what works best in your combination Converter, car weight, rear gear and trans ratio, tire size and so on all play a part on what works best on shift points BTW, I shift my 518 low deck pump gas stroker at 7300 for the best ETs
Re: where do u shift your big block?? [Re: moparmattkos] #480730
09/27/09 02:03 PM
09/27/09 02:03 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
It depends on heads/cam/gear/shift recovery etc every combo it a different - A 400 with MW heads, roller and 5.38's like 8200-8400.
Re: where do u shift your big block?? [Re: MoparJoe] #480731
09/27/09 06:29 PM
09/27/09 06:29 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
I shift my 501 at 6500 and cross at 6800 with lil ez 295's. My head and cam combo are easy on springs and parts and makes good torque. Best of a 10.22 @ 129 in a 3800 pound sled.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: where do u shift your big block?? [Re: 67HEMI] #480732
09/27/09 06:43 PM
09/27/09 06:43 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i was shifting at 6800 but after the bigger carbs i am trying 6500.it works pritty well so far.i just need the 60' to stick.
Re: where do u shift your big block?? [Re: blownzoom440] #480733
09/27/09 07:07 PM
09/27/09 07:07 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
557" aluminum wedge .800 cam 15:1 compression on alky. launch at 6K and shift at 7400-7500 rpms.
Re: where do u shift your big block?? [Re: moparmattkos] #480734
09/27/09 07:10 PM
09/27/09 07:10 PM
ELYRIA,OH
ELYRIA,OH
maybe advance the cam 4*
Re: where do u shift your big block?? [Re: moparmattkos] #480735
09/27/09 08:24 PM
09/27/09 08:24 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
499 B1 @ 7200 9.50 @ 137mph with 488 gears. crossing traps @ 7600 with a glide, car really pulls ontop
Re: where do u shift your big block?? [Re: B1KILLER] #480736
09/27/09 11:35 PM
09/27/09 11:35 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
512 indymaxx B engine with 4.88 gears. change gear @ 7k cross the line @ 7200 doing 9.5@139mph with TF.
