474 combo's
#480670
09/26/09 10:39 PM
09/26/09 10:39 PM
Posts: 2,286 Hamilton,Ont
72chrgrally
Hamilton,Ont
Hey guys I have a buddy that wants to build a 474 stroker. He asked me to post about what your combo is, he isn't computer literate. He is interested in connecting rod, piston, cam and cylinder head information. Also dyno and time slip info would be appreciated. Thanks guys! Steve
Photobucket sucks
Re: 474 combo's
[Re: Cab_Burge]
#480672
09/26/09 10:50 PM
09/26/09 10:50 PM
Posts: 1,704 Nebraska
70VcodeCoronetRT
Nebraska
I'm currently collecting parts to put a 470 together next spring. I plan on building a low deck with 6.700 rods a 1.30 ch piston and a 3.915 stroke crank. This should give me a little room to have the block decked and get close to a zero deck. I'm going to build mine as close as I can to Andy Fs' 550hp build except with a hydraulic roller. Hope this helps a bit.
Re: 474 combo's
[Re: Cab_Burge]
#480673
09/26/09 10:54 PM
09/26/09 10:54 PM
72chrgrally
Hamilton,Ont
Which type block does he want to use? What bore size and stroke does he plan on using?
Sorry its a 400 block, 3.915 stroke, and probably 4.375 or what ever it takes to clean up the bores. He certainly wants to use off the shelf parts. Steve
Re: 474 combo's
[Re: challenger73400]
#480679
09/27/09 11:37 AM
09/27/09 11:37 AM
Posts: 391 Santa Rosa,CA USA
67dodgeracer
Santa Rosa,CA USA
Callies compstar 6.535" chevy rods RPM Eng. 3.90 forged crank J.E. 13-1 Lunati roller .640 lift,.280@.050.w/1.5 rocker. Half fill 400 block w/Pro Gram billet steel caps Home ported early mopar st.6 heads (straight plugs) M1 manifold w/stock #9375 1050 2" Hookers Milodon 7qt. pan w/1/2" internal pickup Best time is 10.02 134mph in 3,400 lb.Coronet,shifted at 6,800. Good luck with the build,they're great reliable motors.
