474 combo's #480670
09/26/09 10:39 PM
09/26/09 10:39 PM
Hamilton,Ont
72chrgrally Offline OP
Hamilton,Ont
Hey guys I have a buddy that wants to build a 474 stroker. He asked me to post about what your combo is, he isn't computer literate. He is interested in connecting rod, piston, cam and cylinder head information. Also dyno and time slip info would be appreciated. Thanks guys!
Steve
Photobucket sucks
Re: 474 combo's [Re: 72chrgrally] #480671
09/26/09 10:45 PM
09/26/09 10:45 PM
Cab_Burge Online work
Cab_Burge  Online Work
Steve
Which type block does he want to use? What bore size and stroke does he plan on using?
Re: 474 combo's [Re: Cab_Burge] #480672
09/26/09 10:50 PM
09/26/09 10:50 PM
Nebraska
70VcodeCoronetRT Offline
Nebraska
I'm currently collecting parts to put a 470 together next spring. I plan on building a low deck with 6.700 rods a 1.30 ch piston and a 3.915 stroke crank. This should give me a little room to have the block decked and get close to a zero deck. I'm going to build mine as close as I can to Andy Fs' 550hp build except with a hydraulic roller. Hope this helps a bit.
Re: 474 combo's [Re: Cab_Burge] #480673
09/26/09 10:54 PM
09/26/09 10:54 PM
Hamilton,Ont
Hamilton,Ont
Sorry its a 400 block, 3.915 stroke, and probably 4.375 or what ever it takes to clean up the bores. He certainly wants to use off the shelf parts.
Steve
Re: 474 combo's [Re: 72chrgrally] #480674
09/26/09 11:00 PM
09/26/09 11:00 PM
Is this a race only motor or street and strip? I have built several motors like that, both B and RB blocks. Does he want to use a Mopar 440 crank to make the stroker or a after market crankshaft? KB sells a forged piston for the low deck using a BB Chevy type after market rod, I don't remember how long though Thumperdart has one that runs pretty good, for a little motor
Re: 474 combo's [Re: 72chrgrally] #480675
09/26/09 11:02 PM
09/26/09 11:02 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
My friend is getting parts together to rebuild his 470 stroker. He just got the custom Ross domed pistons. I think the pistons were $800+ for the set. I think he has 6.70" H-Beam connecting rods, but I will ask him tomorrow when we are putting my transmission in my car.
Re: 474 combo's [Re: 72chrgrally] #480676
09/26/09 11:36 PM
09/26/09 11:36 PM
AndyF Offline
AndyF  Offline
$20 for the book and he'll have the info that he neeeds.
https://board.moparts.org/ubbthreads/show...e=0#Post5020832
Re: 474 combo's [Re: 70VcodeCoronetRT] #480677
09/26/09 11:44 PM
09/26/09 11:44 PM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
Mine is similar to this,
Low deck, 6.700 rods, 1.32 ch and 3.900 stroke and Bulldogs heads.
According to MM compression is 10.02:1
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: 474 combo's [Re: 72chrgrally] #480678
09/27/09 10:12 AM
09/27/09 10:12 AM
southwest Alabama
challenger73400 Offline
southwest Alabama
I went with the chevy length rod of 6.535" on an 3.916" ofset ground steel crank, 440 source pistons and 440 source home ported heads. I am very happy with it.
Re: 474 combo's [Re: challenger73400] #480679
09/27/09 11:37 AM
09/27/09 11:37 AM
Santa Rosa,CA USA
67dodgeracer Offline
Santa Rosa,CA USA
Callies compstar 6.535" chevy rods
RPM Eng. 3.90 forged crank
J.E. 13-1
Lunati roller .640 lift,.280@.050.w/1.5 rocker.
Half fill 400 block w/Pro Gram billet steel caps
Home ported early mopar st.6 heads (straight plugs)
M1 manifold w/stock #9375 1050
2" Hookers
Milodon 7qt. pan w/1/2" internal pickup
Best time is 10.02 134mph in 3,400 lb.Coronet,shifted at 6,800.
Good luck with the build,they're great reliable motors.
