Re: Oil pressure , need help.
[Re: galen]
#480496
09/26/09 10:22 PM
09/26/09 10:22 PM
Indy single line pickup, 7 quart milodon pan, 8 quarts total with filter. I am running .003 on mains, .0025 on rods. I have a .050 jet in each head feeding harland sharp rockers. 440-1s. Brad Penn 15-40, wix racing filter. I changed the guage to a manual, have 35 lbs at idle steady hot, throttle open I can see it go to 80 then drops to 60 like the pump bypass opens. Is this ok or can I shim the spring in the pump. Melling pump, Indy cover. Galen
does it drop back to 60 lbs with no load on the motor at 3500 and higher rpm, or only when under a load?
[Re: galen]
#480498
09/26/09 10:50 PM
09/26/09 10:50 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
What peak RPM are you going to shift the motor at? The 10 lbs per 1000 RPM works really well on most BB Mopars I have seen a 10 HP gain by reducing the oil pressure from 80 lbs at 6500 RPM to 65 lbs at 6500 RPM with 30Wt oil at 170 F I don't run straight 30 WT oil anymore as a results of that dyno session
[Re: galen]
#480499
09/26/09 10:57 PM
09/26/09 10:57 PM
Dan it drops back 3500 or higher, no load.
is this a recent build? you can try replacing the spring and relief valve, but your symptoms are normally associated with vey loose bearing clearances bleeding off a high volume of oil. you might also test the rocker oiling by stepping down to .035 restrictors. use a drill to prime it and see if you have excessive leakage up there.
Cab, i've done dyno testing regarding oil pressure and high/ low volume pumps. the largest differential i ever saw was about 1 horsepower, and that was going all the way down to 45 psi. we documented the tests very carefully matching oil and water temps on each successive pull. give it some thought, a 1/2 HP drill will spin the pump to max pressure and over relief. a 3/4 HP drill will spin it slightly faster, but no difference in pressure or volume is achieved.
[Re: galen]
#480501
09/26/09 11:34 PM
09/26/09 11:34 PM
i wouldn't pull the pan until i tested it, as i outlined above. the pushrods should seal off the lifters, especially if they have a 5/16 ball end.
[Re: galen]
#480504
09/27/09 12:05 AM
09/27/09 12:05 AM
good luck. i hope it's a simple fix.
