Can I make my left turn signal cancel after turning? #479135
09/25/09 12:03 PM
09/25/09 12:03 PM
Whitey Nocar Offline OP
Right side cancels itself out after the turn, left side does not, Is there an easy fix? '68 Coronet 500 stock steering wheel.
Re: Can I make my left turn signal cancel after turning? [Re: Whitey Nocar] #479136
09/25/09 12:09 PM
09/25/09 12:09 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You either need the whole turn sig switch, or you can try the yahovey repair kit that is just the upper part of switch with contacts. I don't even know if that is available anymore. It's not the steering wheel, but wheel has to come off to fix switch.
Re: Can I make my left turn signal cancel after turning? [Re: Whitey Nocar] #479137
09/25/09 12:30 PM
09/25/09 12:30 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Re: Can I make my left turn signal cancel after turning? [Re: Whitey Nocar] #479138
09/25/09 01:29 PM
09/25/09 01:29 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
NAPA sells the item Nacho shows. Worked for me and a lot cheaper than buying a new switch.
Re: Can I make my left turn signal cancel after turning? [Re: 70Duster440] #479139
09/25/09 01:53 PM
09/25/09 01:53 PM
Lawrence, KS
coledavis01 Offline
coledavis01  Offline
Lawrence, KS
I got that same item for my 69 for less than $6.00 at advance auto. Once the steering wheel is off its a very easy fix.
I'd recommend cleaning the conacts up while you're at it and testing to make sure all the lights are working properly before you install the steering wheel.
Cole
Re: Can I make my left turn signal cancel after turning? [Re: coledavis01] #479140
09/25/09 04:06 PM
09/25/09 04:06 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yep all you want is the turn signal cam. Stock and repro ones are plastic and it's a wonder they last as long as they do before cracking.
Re: Can I make my left turn signal cancel after turning? [Re: coledavis01] #479141
09/25/09 05:40 PM
09/25/09 05:40 PM
Cole
so, to take off the steering wheel...I haven't looked yet but does the center piece just pop off and then a castle nut or something
Re: Can I make my left turn signal cancel after turning? [Re: Whitey Nocar] #479142
09/25/09 06:16 PM
09/25/09 06:16 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Depends on the steering wheel. There may be screws on the back side of the wheel that hold the horn pad on.
Disconnect the battery first. Remove the horn pad/button. Remove the big nut on the end of the shaft. Use a wheel puller to remove the wheel. There are different styles, but will look something like this:
Re: Can I make my left turn signal cancel after turning? [Re: 70Duster440] #479143
09/26/09 10:48 PM
09/26/09 10:48 PM
Cool, thanks everyone for the advise! sounds easy enough.
