Street Hemi Cam Grind (B/RB)
#478041
09/24/09 01:45 AM
09/24/09 01:45 AM
Posts: 5,166 CT
GTX MATT
CT
Does anyone sell the old street hemi grind anymore or anything similar?
Re: Street Hemi Cam Grind (B/RB)
[Re: ZIPPY]
#478048
09/24/09 11:17 AM
09/24/09 11:17 AM
Posts: 5,166 CT
GTX MATT
CT
So the 280 .474 lift will work just as well? I had thought it was similar but I knew the original hemi grind specs were different.
Would this cam work alright with stock stall and 3.23 or 3.55 gears? It seems a little too big to me.
I'll be in a '68 440, with headers and an Eddy Performer RPM, 800 with vaccuum secondaries.
[Re: magnum440]
#478052
09/24/09 03:10 PM
09/24/09 03:10 PM
Posts: 12,408 Taxes & Virus's R-US, NY
Dragula
Both the .474 and .484/284 will want a higher stall than stock. A better cam for a stock convertor'd car is the new Comp Cams .525" lift 231* duration at 50...HL275 or something. This cam works super well with 3.23 gears and stock convertor. We have broken 3 posi units and one drive shaft with it already in our street car. I wouldn't recomend it if we hadn't run it in a bunch of cars and had it outperform eveything else in a nearly stock application.
[Re: Dragula]
#478053
09/24/09 04:07 PM
09/24/09 04:07 PM
Posts: 3,001 Coram, NY
Pool Fixer
Coram, NY
I run the 4452993 cam in my charger. 2800 converter block zero decked with SRP flat tops, true 10:1, 346 heads with 2.14/1.81 valves. bowls and short turns blended.
with 1 3/4" headers, 3.55 gears and huge diameter hoosier quick times, I ran a 13.1 @ 105. Didn't to any tuning at all really. that was with an edelbrock eps750 carb, box stock.
I am now running street tires, mighty demon 750, 3.91's, and stock HP manifolds. haven't been to the track though.
[Re: GTX MATT]
#478054
09/24/09 08:25 PM
09/24/09 08:25 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Street Hemi Grind cam is a real good one to use.Still using the old one that Dad bought in 1972 in the 383 Road Runner,only cam we ran in that car and went 12.26 in Atlanta with the usual bolt ons and 4.88's with a 4-speed.After I got the car,I put in 3.23's and used the OEM 585 cfm Holley and stock 666 intake and the car ran very well with it.I'm going to stil use the same cam when I finish restoring the car later this year.
[Re: Chris2581]
#478055
04/18/10 11:28 AM
04/18/10 11:28 AM
Posts: 6,097 Valencia, España
NachoRT74
Valencia, España
floating back this thread... what's the spec at .050 ? on both "Hemi grind" cams old, ( 284/471-474, 108 ) and new ( 280/474, 110 ). I know the newer is rated on manuals as 238 what aparently is really closer to 234 and not 238, as somebody measured sometime ago.
will be nice to get CERTAIN MEASURED SPECS and not simply especulations
[Re: GTX MATT]
#478056
04/18/10 10:56 PM
04/18/10 10:56 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
I've run this cam in my street car for over 10 years. I have a similar combination but run low compression, (around 9.3:1). I often think about putting a mild solid in the car (MP.528), but the combination is just so sweet as a driver. I added eddy rpm heads a few years ago and picked up a surprising 1000 rpm. It also doesn't seem to mind 87 octane.
The 3800 lb car runs mid 12's, 107-109 mph with a stock factory 22-2400 converter and 3.23 gear. It all depends where you shift the car. 4.10 gears are just a little too much and require 6100 rpm shifts to net 12.2 at 111.9 mph.
3.73 or 3.9 gear is the max gear I would ever use if I chose to compete with this cam.
I don't think a cam change is worth the few tenths gain for the few trips to the track. The big fat torque is right there in the driving range at all times for such a mild motor.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: NachoRT74]
#478058
04/19/10 07:26 PM
04/19/10 07:26 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Measured by Lew: 280/474 234@0.050, 140@0.200 284/484, 238@0.050, 146@0.200
Don't have the old Hemi Grind #s
