Street Hemi Cam Grind (B/RB) #478041
09/24/09 01:45 AM
09/24/09 01:45 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Does anyone sell the old street hemi grind anymore or anything similar?
Re: Street Hemi Cam Grind (B/RB) [Re: GTX MATT] #478042
09/24/09 03:58 AM
09/24/09 03:58 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Surely Mopar Performance does. I think it's 280 duration .474 lift. Comp has something similar in the Purple Plus line. Or just call Racer Brown and tell Jim what you want.
Re: Street Hemi Cam Grind (B/RB) [Re: bobby66] #478043
09/24/09 05:22 AM
09/24/09 05:22 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I believe they were 484 lift and 284 duration.
Re: Street Hemi Cam Grind (B/RB) [Re: SNK-EYZ] #478044
09/24/09 07:36 AM
09/24/09 07:36 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
That is the one....
Re: Street Hemi Cam Grind (B/RB) [Re: bobby66] #478045
09/24/09 08:19 AM
09/24/09 08:19 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
that is the old street hemi grind...actually it is the revised one...the older one had a little less duration.
Tony
70 AARCuda Vitamin C
Re: Street Hemi Cam Grind (B/RB) [Re: 70AARcuda] #478046
09/24/09 09:46 AM
09/24/09 09:46 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Old Street Hemi grind was cam # was P3690214,284/470.The 284/484 was the next step up.Looking for one myself.Have the 284/470 in the bird since 92,one of the best cam's I ever used.Still there after 17yrs.
Re: Street Hemi Cam Grind (B/RB) [Re: GTX MATT] #478047
09/24/09 09:52 AM
09/24/09 09:52 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The original one was P3690214, 284 advertised duration .471 intake, .474 exhaust on 108.
In 1983 it was replaced by P4286631, 280 duration .474 lift, straight pattern on 110. The idea was to improve both idle quality and power.
In 1989, P4286631 was replaced by P4452993 which has identical specs, and the 993 is still a good part number today.
It's still a good street cam for a near stock 440, the best thing about it is not finicky about gear and converter. Also works well with low compression.
Re: Street Hemi Cam Grind (B/RB) [Re: ZIPPY] #478048
09/24/09 11:17 AM
09/24/09 11:17 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
So the 280 .474 lift will work just as well? I had thought it was similar but I knew the original hemi grind specs were different.
Would this cam work alright with stock stall and 3.23 or 3.55 gears? It seems a little too big to me.
I'll be in a '68 440, with headers and an Eddy Performer RPM, 800 with vaccuum secondaries.
Re: Street Hemi Cam Grind (B/RB) [Re: GTX MATT] #478049
09/24/09 11:27 AM
09/24/09 11:27 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The 474 cam will work with stock converter, but will work much nicer with higher stall converter.
Re: Street Hemi Cam Grind (B/RB) [Re: buildanother] #478050
09/24/09 01:01 PM
09/24/09 01:01 PM
Central NC
gch Offline
gch  Offline
Central NC
The .280-.474 would work better advanced 2-4 degrees.If you want MP the 272-.455 would probably work better.
Re: Street Hemi Cam Grind (B/RB) [Re: GTX MATT] #478051
09/24/09 01:39 PM
09/24/09 01:39 PM
texas
magnum440 Offline
magnum440  Offline
texas
ive been using 474/280 cam in my 440 for yrs now,,im using 383 convertor (which is higher stall than 440 convertor) magnum manifolds with 3.55s... i have a/c & power brakes. would rec. to degree it in..
Re: Street Hemi Cam Grind (B/RB) [Re: magnum440] #478052
09/24/09 03:10 PM
09/24/09 03:10 PM
Dragula Offline
Dragula  Offline
Both the .474 and .484/284 will want a higher stall than stock. A better cam for a stock convertor'd car is the new Comp Cams .525" lift 231* duration at 50...HL275 or something. This cam works super well with 3.23 gears and stock convertor. We have broken 3 posi units and one drive shaft with it already in our street car. I wouldn't recomend it if we hadn't run it in a bunch of cars and had it outperform eveything else in a nearly stock application.
Re: Street Hemi Cam Grind (B/RB) [Re: Dragula] #478053
09/24/09 04:07 PM
09/24/09 04:07 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
I run the 4452993 cam in my charger. 2800 converter block zero decked with SRP flat tops, true 10:1, 346 heads with 2.14/1.81 valves. bowls and short turns blended.
with 1 3/4" headers, 3.55 gears and huge diameter hoosier quick times, I ran a 13.1 @ 105. Didn't to any tuning at all really. that was with an edelbrock eps750 carb, box stock.
I am now running street tires, mighty demon 750, 3.91's, and stock HP manifolds. haven't been to the track though.
Re: Street Hemi Cam Grind (B/RB) [Re: GTX MATT] #478054
09/24/09 08:25 PM
09/24/09 08:25 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Street Hemi Grind cam is a real good one to use.Still using the old one that Dad bought in 1972 in the 383 Road Runner,only cam we ran in that car and went 12.26 in Atlanta with the usual bolt ons and 4.88's with a 4-speed.After I got the car,I put in 3.23's and used the OEM 585 cfm Holley and stock 666 intake and the car ran very well with it.I'm going to stil use the same cam when I finish restoring the car later this year.
Nautilus Racing-
Re: Street Hemi Cam Grind (B/RB) [Re: Chris2581] #478055
04/18/10 11:28 AM
04/18/10 11:28 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
floating back this thread... what's the spec at .050 ? on both "Hemi grind" cams old, ( 284/471-474, 108 ) and new ( 280/474, 110 ). I know the newer is rated on manuals as 238 what aparently is really closer to 234 and not 238, as somebody measured sometime ago.
will be nice to get CERTAIN MEASURED SPECS and not simply especulations
Re: Street Hemi Cam Grind (B/RB) [Re: GTX MATT] #478056
04/18/10 10:56 PM
04/18/10 10:56 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
I've run this cam in my street car for over 10 years. I have a similar combination but run low compression, (around 9.3:1). I often think about putting a mild solid in the car (MP.528), but the combination is just so sweet as a driver. I added eddy rpm heads a few years ago and picked up a surprising 1000 rpm. It also doesn't seem to mind 87 octane.
The 3800 lb car runs mid 12's, 107-109 mph with a stock factory 22-2400 converter and 3.23 gear. It all depends where you shift the car. 4.10 gears are just a little too much and require 6100 rpm shifts to net 12.2 at 111.9 mph.
3.73 or 3.9 gear is the max gear I would ever use if I chose to compete with this cam.
I don't think a cam change is worth the few tenths gain for the few trips to the track. The big fat torque is right there in the driving range at all times for such a mild motor.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Street Hemi Cam Grind (B/RB) [Re: racealittle] #478057
04/19/10 12:25 AM
04/19/10 12:25 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
engine? I guess 440...
Re: Street Hemi Cam Grind (B/RB) [Re: NachoRT74] #478058
04/19/10 07:26 PM
04/19/10 07:26 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Measured by Lew:
280/474 234@0.050, 140@0.200
284/484, 238@0.050, 146@0.200
Don't have the old Hemi Grind #s
