moly rollbar vs. steel bar weight difference #477889
09/23/09 09:35 PM
09/23/09 09:35 PM
Wi.
65_gt_rag_402 Offline OP
Wi.
How much weight difference is there between a 6 point moly roll bar vs. a steel bar??
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!! 11.0's on pump gas .
Re: moly rollbar vs. steel bar weight difference [Re: 65_gt_rag_402] #477890
09/23/09 09:52 PM
09/23/09 09:52 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
This question cannot be answered if you want a legal roll bar. There is no 1 3/4" .083" chrome moly tubing. A legal roll bar, not cage, is required to have 1 3/4" main hoop instead of 1 5/8" tube diameter.
If you are blowing off the rules and go with Chrome moly you will save 35 pounds give or take.
Leon
Re: moly rollbar vs. steel bar weight difference [Re: 65_gt_rag_402] #477891
09/23/09 10:02 PM
09/23/09 10:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you want a tubing weight calculator... use this
www.steel-pipes-tubes.com/steel-pipe-weight-calculator.html
Re: Chromoly roll bar vs. steel bar weight difference [Re: Leon441] #477892
09/23/09 10:30 PM
09/23/09 10:30 PM
Wi.
Wi.
I want the bar to legal and to specs.
how much weight is added to the car with a roll bar in steel or chromoly ?
Re: Chromoly roll bar vs. steel bar weight difference [Re: 65_gt_rag_402] #477893
09/23/09 11:31 PM
09/23/09 11:31 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
One foot of 1.75" x 0.118" 1020 Steel tubing by 12 inches long weighs 2.07lbs. The same length in 1.625" x 0.083" 4130 N tubing weighs 1.37lbs. There is around 15 feet in a main hoop, give or take a foot or two. Do the math
AL....
Alan Jones
Re: Chromoly roll bar vs. steel bar weight difference [Re: LA360] #477894
09/24/09 12:45 AM
09/24/09 12:45 AM
None of the chassis shops I know of use .118 mild steel tubing anymore, they all use .130 wall due to some of the .120 and .118 tubing being less than .117 in some spots, especially around the bends My chrome moly roll bar has never been rejected at any race track, NHRA or others wise
Re: moly rollbar vs. steel bar weight difference [Re: Leon441] #477895
09/24/09 07:08 AM
09/24/09 07:08 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Leon
I dont understand no legal moly bar. S/W race sels them and other comp.
Re: moly rollbar vs. steel bar weight difference [Re: Scamp408] #477896
09/24/09 07:54 AM
09/24/09 07:54 AM
I have a six-point chrome-moly bar in my duster,its GOOD down to 10.0's..
Re: moly rollbar vs. steel bar weight difference [Re: Leon441] #477897
09/24/09 09:04 AM
09/24/09 09:04 AM
Lebanon,IN
mr2performance Offline
Lebanon,IN
"There is no 1 3/4" .083" chromoly" I have a whole bunch of it in my steel rack. Mike
MR2PERFORMANCE RACE CARS 765 483 9371
Re: moly rollbar vs. steel bar weight difference [Re: mr2performance] #477898
09/24/09 09:13 AM
09/24/09 09:13 AM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Re: moly rollbar vs. steel bar weight difference [Re: mr2performance] #477899
09/24/09 09:17 AM
09/24/09 09:17 AM
Jersey shore
Gary67 Offline
super street
Gary67  Offline
super street
Jersey shore
I'm pretty sure it's 38% lighter when comparing .134 steel to .083 moly...Moly is stronger so you can use thinner wall, same wall thickness they actually weigh the same...On the SW site if you look in the FAQ section they say a 100# roll bar in .134 steel would be 62# in .083 moly...
Re: moly rollbar vs. steel bar weight difference [Re: Gary67] #477900
09/24/09 09:22 AM
09/24/09 09:22 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Guess I didn't look close enough at S&W's site then...was trying to find that info myself
So a reasonable estimate is a 40 lb weight saving for the moly (which has to be TIG welded of course)?
Re: moly rollbar vs. steel bar weight difference [Re: DrCharles] #477901
09/24/09 10:12 AM
09/24/09 10:12 AM
Jersey shore
Gary67 Offline
super street
Gary67  Offline
super street
Jersey shore
I believe that's correct..I went 8 point mild steel, mig ,that's what type welder we had. but if you go to the link here Moly and click roll cage faqs you will find it.
Re: moly rollbar vs. steel bar weight difference [Re: Gary67] #477902
09/24/09 10:59 AM
09/24/09 10:59 AM
USA
Ron Silva Offline
Ron Silva  Offline
USA
If you want to save weight go with a Moly bar and make it a 5 pt and use the 1-1/4" cross bar that the rules allow. I had to buy that piece separate since my kit came with a 1-3/4" cross bar.
SRT DEMON ONE SEAT
Re: moly rollbar vs. steel bar weight difference [Re: 65_gt_rag_402] #477903
09/24/09 09:51 PM
09/24/09 09:51 PM
Wi.
Wi.
That was very interesting ! and helpful .
I wish I could do the job myself But I do not have the tig welder or bender. Soooooo. I have a fab shop picked out to do the job.
another question ... Can I have a hinge/swing bar installed for the drivers door. or is there other regulations on that issue ?
Re: moly rollbar vs. steel bar weight difference [Re: 65_gt_rag_402] #477904
09/24/09 10:01 PM
09/24/09 10:01 PM
I believe you can have a swing out door bar as long as you don't need a cage, convertible have different rules than the rest of us hardtop racers do Call your local track tech guys and ask them to be sure Or better yet E mail them so you get a written responce that you can take with you
Re: moly rollbar vs. steel bar weight difference [Re: Cab_Burge] #477905
09/25/09 12:55 AM
09/25/09 12:55 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
swing out bars will cert to 8.50 as long as they are installed properly.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: moly rollbar vs. steel bar weight difference [Re: Cab_Burge] #477906
09/25/09 12:55 AM
09/25/09 12:55 AM
Glendale AZ
Comp Chassis 2 Offline
Glendale AZ
A swing out door bar is legal on any roll bar,or rollcage to 8.50 as long as the design meets NHRA specs
